egt mounting question
Old Aug 4, 2004 | 04:23 AM
Btothe3rdDegree's Avatar
Default egt mounting question
i am getting ready to mount my egt on my mani, i have read that most people mount it on the 3rd cylinder, the problem with that is my wastegate tube is right there and i dont know if i have the room for it or if the WG being right there will mess up the reading, also its a autometer and they recomend if it is a turbo car to put it after the turbo, why would i want to do that? and finally it needs a 12 volt connection, is that a constant 12 volt or can i hook it up to my accesory?
thanks
Old Aug 4, 2004 | 07:25 AM
notoriousB's Avatar
Default Re: egt mounting question (Btothe3rdDegree)
accessory 12v will be fine, I'm also curious on the before/after turbo question as I too will be installing an EGT probe soon
Old Aug 4, 2004 | 07:54 AM
Griffin@Camtech's Avatar
I have alyways been told to use the number 3 cyl
Old Aug 4, 2004 | 08:59 AM
Default Re: egt mounting question (Stickdeath)
anyone else?
Old Aug 4, 2004 | 09:46 AM
m R g S r's Avatar
Some put it on the manifold near runner # 3 and some on the downpipe. If you place it on the downpipe, you will see lower EGT's because the gas has a little room to cool down. I wouldn't use that as your only source to tune, because of this reason, there is no one temperature that you should shoot for.
Old Aug 4, 2004 | 06:22 PM
Default Re: egt mounting question (m R g S r)
so 3rd cylinder? does it matter how far from the head it should be?
Old Aug 4, 2004 | 06:48 PM
m R g S r's Avatar
Like I said, you can put it where you want, it will just give you a different reading.
Old Aug 4, 2004 | 07:34 PM
MooreBoost's Avatar
I have mine in the o2 sensor location of my HF mani.
Old Aug 5, 2004 | 04:25 AM
Default Re: egt mounting question (tegunderpressure)
what about the WG being on the 3rd runner will that cause inconsistancies? i have to ask, why is the egt put on the 3rd runner?
Old Aug 5, 2004 | 04:48 AM
90teg's Avatar
why do you need an EGT?
Modified by 90teg at 6:38 AM 8/5/2004
Old Aug 5, 2004 | 04:49 AM
#3 tends to run hotter then the rest. as far as the wastegate I would say as long as it is a good 1 to 2" in front of it you should be fine
Old Aug 5, 2004 | 04:58 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stickdeath &raquo;</TD></TR><TR><TD CLASS="quote">#3 tends to run hotter then the rest. as far as the wastegate I would say as long as it is a good 1 to 2" in front of it you should be fine</TD></TR></TABLE>
yeah there is like 3 in from the head to the WG so i dont know if it will be able to go there, although the WG is on a 90 degree elbow, do you think that will make a difference?
Old Aug 9, 2004 | 04:56 AM
anyone know if the wastegate will cause a problem? if i cant run it on the 3rd runner which one should i run it on?
Old Aug 10, 2004 | 09:17 AM
ttt
Old Aug 10, 2004 | 10:34 AM
donkiman's Avatar
Default Re: egt mounting question (90teg)
to catch a problem before its a real problem
Old Aug 10, 2004 | 10:37 AM
donkiman's Avatar
Default Re: egt mounting question (donkiman)
heres a pic of my intsall
Old Aug 11, 2004 | 06:32 PM
so if i cant run it on the 3rd runner because of the WG, which runner should i put it on?
Old Aug 11, 2004 | 10:54 PM
Tchleung's Avatar
put it on the downpipe right after the turine like 1-2" away.
Old Aug 12, 2004 | 03:49 AM
Default Re: (Tchleung)
is that a good spot? i thought the turbo changes the temps dramatically?
Old Aug 12, 2004 | 07:49 AM
Tchleung's Avatar
that's why you put it as close to the turbo as possible. it'll be like running the EGT on #2. it won't be the exact reading you want. but it'll be close. Usually when peopel can't mount it on #3, they mount it on the downpipe
Old Aug 12, 2004 | 09:43 AM
B18EG6's Avatar
i put mine in the DP
Old Aug 12, 2004 | 10:31 AM
FuriousGeorge's Avatar
one of the main reasons people put the egt probe after the turbo is that if there were to ever be a problem with the probe (like say, a piece of it broke off) it wouldnt hurt the turbine at all.
Old Aug 12, 2004 | 11:14 AM
Tchleung's Avatar
Default Re: (B18EG6)
B18EG6: That's a very good idea!! Props
Old Aug 15, 2004 | 04:14 PM
playAho's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by donkiman &raquo;</TD></TR><TR><TD CLASS="quote">heres a pic of my intsall </TD></TR></TABLE>
isn't that the #2 cylinder?
Old Aug 15, 2004 | 04:42 PM
wantboost's Avatar
Who is Mr Robot?
yea, it is, if you are looking at the block in your car, then from the left, it is 4-3-2-1
