9005 conversion installed
Old Aug 3, 2004 | 11:01 PM
sumyungguy's Avatar
Default 9005 conversion installed
noticed this cheap lighting up grade a while back and finally did it. Thanks to PatrickGSR94's link (<A HREF="http://www.bmwe34.net/E34main/Upgrade/More_light.htm
" TARGET="_blank">http://www.bmwe34.net/E34main/...htm
</A>) that made it a very simple process. Most people may say just get HID's or fog lights, but I would try this first. I used the 9005 sylvania silverstar bulbs and it they work great. Matter of fact while I was out i was next to a new Escalade (which had HID's) at a stop light and my lights were showing things better than his. so if your cheap with crappy headlights give this a shot.
Old Aug 3, 2004 | 11:29 PM
Jason84's Avatar
Default Re: 9005 conversion installed (sumyungguy)
think ill stick with those versuses melting the headlight housings...
Old Aug 4, 2004 | 05:17 AM
slomob18b's Avatar
Default Re: 9005 conversion installed (Jason84)
As long as the 9006 bulbs you are modifying do not use too much wattage it ill not melt the headlight harness or housing.
Old Aug 4, 2004 | 06:10 AM
CNSK's Avatar
I would have to disagreed on the 9005 conversion silverstar...i did it and its not all that great....I compared it to my buddys s2g...and s2g's HID just killed my 9005 conversion...nothing in comparison...put me in shame...
Old Aug 4, 2004 | 07:55 AM
RuskeR's Avatar
Default Re: 9005 conversion installed (Moua)
Well no one ever said this conversion would be HID's the shame. Why would you ever compare a halegon bulb to a xenon bulb?
Now compare your silverstars to OEM stock bulbs. It's look alot better. This mod is worth it in my opinion. Anything is better than stock.
Old Aug 4, 2004 | 06:46 PM
tremor86's Avatar
Default Re: 9005 conversion installed (RuskeR)
What wattage bulb will cause problems with melting and so on?
Old Aug 4, 2004 | 07:05 PM
Rtistik.'s Avatar
Default Re: 9005 conversion installed (tremor86)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tremor86 &raquo;</TD></TR><TR><TD CLASS="quote">What wattage bulb will cause problems with melting and so on?</TD></TR></TABLE>
want to do this mod but never heard of too much wattage causing problems, what wattage won't cause me a headache?
Old Aug 4, 2004 | 07:50 PM
slomob18b's Avatar
Default Re: 9005 conversion installed (rtistik)
Usually those cheap "hid" look bulbs draw more wattage. I have heard cases where they melt the factory harness. I used some factory replacement 9005 and they work just fine. Brighter than the stock 9006.
Old Aug 4, 2004 | 08:25 PM
Gerbilo's Avatar
Default Re: 9005 conversion installed (slomob18b)
https://honda-tech.com/zerothread?id=919047
there is the writeup I did a few weeks ago, check it out
Old Aug 4, 2004 | 09:54 PM
TrueUntilDeath.com's Avatar
i did this mod as well, light output looked the same. then i got hids, dont think ill ever go back to halogens
Old Aug 4, 2004 | 10:21 PM
ophdehEEzY
Guest
Posts: n/a
Default Re: 9005 conversion installed (GMR MM12)
silverstars lasted me about 2 months
but they work great though
Old Aug 5, 2004 | 02:23 PM
TunerN00b's Avatar
Default Re: 9005 conversion installed (ophdehEEzY)
Just for reference, but the conversion is not legal, since the law caps low beam bulbs at 55 watts. However, I don't know how you'd ever get in trouble for it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rtistik &raquo;</TD></TR><TR><TD CLASS="quote">want to do this mod but never heard of too much wattage causing problems, what wattage won't cause me a headache?</TD></TR></TABLE>
I've seen some bulbs rated as high as 100 watts. I've avoid anything much over 65, which is what factory high beams are.
Old Aug 5, 2004 | 02:31 PM
Default Re: 9005 conversion installed (TunerN00b)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TunerN00b &raquo;</TD></TR><TR><TD CLASS="quote">Just for reference, but the conversion is not legal, since the law caps low beam bulbs at 55 watts. However, I don't know how you'd ever get in trouble for it.
I've seen some bulbs rated as high as 100 watts. I've avoid anything much over 65, which is what factory high beams are.</TD></TR></TABLE>
lol, since when does the law matter to modified cars? hah jk
Old Aug 5, 2004 | 05:10 PM
sumyungguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GMR MM12 &raquo;</TD></TR><TR><TD CLASS="quote">
lol, since when does the law matter to modified cars? hah jk</TD></TR></TABLE>
i agree
if i got pulled over i think that would be the last thing on the list
Old Nov 8, 2004 | 06:51 AM
WRTEG's Avatar
9005 Conversion in my 94 Integra LS
tooters bmx
12
Nov 10, 2017 10:04 AM
idobref
Nov 25, 2007 10:07 PM
ac_attak
Aug 1, 2007 04:46 AM
JadeDM
Feb 16, 2007 08:17 PM
97teg415
Aug 21, 2002 11:25 PM
