9005 conversion installed
noticed this cheap lighting up grade a while back and finally did it. Thanks to PatrickGSR94's link (<A HREF="http://www.bmwe34.net/E34main/Upgrade/More_light.htm
" TARGET="_blank">http://www.bmwe34.net/E34main/...htm
</A>) that made it a very simple process. Most people may say just get HID's or fog lights, but I would try this first. I used the 9005 sylvania silverstar bulbs and it they work great. Matter of fact while I was out i was next to a new Escalade (which had HID's) at a stop light and my lights were showing things better than his. so if your cheap with crappy headlights give this a shot.
I would have to disagreed on the 9005 conversion silverstar...i did it and its not all that great....I compared it to my buddys s2g...and s2g's HID just killed my 9005 conversion...nothing in comparison...put me in shame...
Well no one ever said this conversion would be HID's the shame. Why would you ever compare a halegon bulb to a xenon bulb?
Now compare your silverstars to OEM stock bulbs. It's look alot better. This mod is worth it in my opinion. Anything is better than stock.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tremor86 »</TD></TR><TR><TD CLASS="quote">What wattage bulb will cause problems with melting and so on?</TD></TR></TABLE>
want to do this mod but never heard of too much wattage causing problems, what wattage won't cause me a headache?
Usually those cheap "hid" look bulbs draw more wattage. I have heard cases where they melt the factory harness. I used some factory replacement 9005 and they work just fine. Brighter than the stock 9006.
https://honda-tech.com/zerothread?id=919047
there is the writeup I did a few weeks ago, check it out
Just for reference, but the conversion is not legal, since the law caps low beam bulbs at 55 watts. However, I don't know how you'd ever get in trouble for it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rtistik »</TD></TR><TR><TD CLASS="quote">want to do this mod but never heard of too much wattage causing problems, what wattage won't cause me a headache?</TD></TR></TABLE>
I've seen some bulbs rated as high as 100 watts. I've avoid anything much over 65, which is what factory high beams are.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TunerN00b »</TD></TR><TR><TD CLASS="quote">Just for reference, but the conversion is not legal, since the law caps low beam bulbs at 55 watts. However, I don't know how you'd ever get in trouble for it.
I've seen some bulbs rated as high as 100 watts. I've avoid anything much over 65, which is what factory high beams are.</TD></TR></TABLE>
lol, since when does the law matter to modified cars? hah jk
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GMR MM12 »</TD></TR><TR><TD CLASS="quote">
lol, since when does the law matter to modified cars? hah jk</TD></TR></TABLE>
i agree
if i got pulled over i think that would be the last thing on the list
i agree
tooters bmx
12
Nov 10, 2017 10:04 AM
idobref
Nov 25, 2007 10:07 PM
versuses melting the headlight housings...
