will intake invalid warranty??
Old Aug 3, 2004 | 05:24 PM
andylauiii's Avatar
Default will intake invalid warranty??
actually i got 2 questions... 1. will my intake invalid my factory warranty?? i have a 2000 integra... since my brake light comes on even when i release my hand brake..so i wanna go back to dealer to have them fix...
also 2. i have to do a smog check... do you think an aem short ram will pass the test? i think it will but i want to make sure before i go...
thank you so much for helping me!
Old Aug 3, 2004 | 05:46 PM
Savv's Avatar
Default Re: will intake invalid warranty?? (andylauiii)
1) I am not sure about the warrenty, I am sure that it may have some effect, just call and ask and don't tell them who you are and finally if in doubt throw your stock intake back on when you take it to the dealership
2) Also I don't think you will have any problems with the Intake passing smog, I am not from CA and we don;t have smog, but I know people in CA that have way more than an intake, but having the CARB sticker on there will help
Old Aug 3, 2004 | 05:54 PM
andylauiii's Avatar
Default Re: will intake invalid warranty?? (Wild0ne21)
thanks for the info..Wild0ne21...
anyone know more about warranty? the dealer is closed right now..so see if any of you guys know the answer..otherwise i can call tomorrow morning and ask...
Old Aug 3, 2004 | 06:10 PM
shamoo's Avatar
Will you make something up for me please?
Just FYI, if the "BRAKE" light comes on even when the E-brake handle is down, check your brake fluid. It's probably low. That's an indicator for it.
As for the warranty issue.....TECHNICALLY, it should not make a difference, but depending on the dealer, they might give you grief for it. If you decide to take it further, there is a certain clause (I don't remember the name) that is in your favor. You can bring it up if they give you problems.
Most likely, just an intake won't upset them.
Old Aug 3, 2004 | 06:12 PM
xprohx's Avatar
I think too much
An intake will not void your warranty. I also have a 2000 gsr, and today I took it in for an oil change and valve adjustment. After the service was done they gave me a rundown of the level of my fluids, brakes, tires and air filter. And because my filter was an aftermarket filter (injen cai), they said it didn't need to be changed.
As for smog, don't worry about it.
Old Aug 3, 2004 | 06:23 PM
andylauiii's Avatar
Default Re: will intake invalid warranty?? (xprohx)
thank you sooo much for the information! i'll take it to the dealer tomorrow and have them take a look hopefully it'll be fine
Old Aug 4, 2004 | 06:55 AM
steven975's Avatar
I had an AEM intake and Comptech header.
my engine blew up (hole in the block) and Acura replaced it under warranty. They ruled out hydrolock and the ECU showed no sign of over-rev.
now, some dealers have a different attitude, but Honda probably won't deny coverage. Now, some dealers are such a-holes that they may deny on the spot without even asking Honda. Ask you dealer...if they deny, try another.
the brake light thing is on because you need a tad more fluid. my dealer added it for FREE.
intake should not affect smog.
Old Aug 4, 2004 | 06:58 AM
DAsix's Avatar
anytime you change OEM parts the warranty for that object like the "Engine" will be void or pended.
MatT3T4
Honda Fit
Jun 25, 2011 10:13 PM
The-Kid
May 21, 2007 10:36 AM
xd69
Sep 17, 2004 04:11 PM
lahight
Feb 13, 2004 01:25 PM
South Bay Surfer
29
Oct 14, 2002 02:35 PM
