Water Pump leaking need advise
Old Aug 3, 2004 | 04:58 PM
scuba123's Avatar
Default Water Pump leaking need advise
Sup all,
I have a '94 civic that has a leaking water pump. I am completely broke at the moment and can't afford to get the sucker fixed. Will it be detrimental if I continue to drive it for a month going about 70 miles a day? It doesn't over heat yet but I do need to put in coolant on occasion. Do you think she will last? I don't want to damage the timing belt and have the engine explode but I need to get to work. Any help would be great. Thanks
Old Aug 3, 2004 | 07:38 PM
Jimmy's Avatar
Global Moderator
Save some money.. cause if you keep driving it your eventually just going to cause more and more problems..
new water pump is like 50.00
You shouldn't have a car if you can't afford to take care of it
Old Aug 3, 2004 | 08:23 PM
Ryan C's Avatar
Default Re: (Jimmy)
it means its no good. its prolly leaking from the 'weep' holes to tell you that it is junk before somthin bad happens... fix it
Old Aug 3, 2004 | 08:55 PM
turbohondask's Avatar
Default Re: (Ryan C)
fix if befor the bearing fails, and it will chew up the timing belt, then it will be more to buy a new engine.
Old Aug 3, 2004 | 11:54 PM
IVI's Avatar
IVI
Default Re: (turbohondask)
70 miles is alot.
just get it fixed or your going to have to pay alot more later on.
put it on a credit card if you can and then pay it asap.
Old Aug 4, 2004 | 02:07 AM
1.8turbolsvtec's Avatar
Default Re: (IVI)
keep driving it and you will not need a water pump you will need a motor
Old Aug 4, 2004 | 05:50 AM
Xxcivic99xX's Avatar
Default Re: Water Pump leaking need advise (scuba123)
yeah, 70 is a lot....and eventually it's going to leak a lot more causing more problems. so get it fixed. waterpumps are like 35-55 dollars. it probably be around 200-250 to have fixed
wedtm
Mar 26, 2008 07:59 PM
pnthr30
Oct 28, 2003 08:38 AM
Sephro
Mar 20, 2003 11:19 AM
wonny
Dec 7, 2002 05:45 AM
Volcom
Jan 23, 2002 10:31 AM
