Can you name this Mitsubishi Turbo and wheres its from?
EDIT: BETTER PICS
I believe its a Mitsubishi TDO5-20G turbo but I am not 100% sure. Anyone know what cars these turbos came stock in because I need to look for a new one at a junkyard. Thanks
Modified by SynTeg at 8:03 PM 8/3/2004
Modified by SynTeg at 8:17 PM 8/3/2004
The seals on the exhaust and compressor sides are blown, so i'll need a rebuild for sure. And they guy I got the turbo from welded the Downpipe and External wastegate directy to the exhaust side so i'll need to take it to a machineshop to have it shave down to normal again. And also there is a bolt with no head in one of the holes to mount an exhaust flange. I dont know if all this work is worth it or just to buy the same turbo from a junkyard since I already have a manifold and a exhaust flange for it.
Might be easier to swap in a T28.
The beauty of the DSM turbos is all of the inlet and outlet flanges are the same between the various turbos.
The DSM guys even made a special turbine housing that fits the DSM pattern and bolts to a T3:
http://cgi.ebay.com/ws/eBayISA...=WDVW
It spooled up real nice on my dohc zc with only 5lbs of boost. I was ready to put in a walbro 255hp fuel pump and a safc-II hack in and up the boost to 9-10lbs but then a kink came up on the oil return line causing the seals to blow
Thats an excellent idea, do you have a link to the DSM boards? I will definately try to find a exhaust housing rather than take it to a machine shop. Thanks.
I love the top end on the 20G i'll definately stick with it.
The guy I got the turbo from Welded the downpipe + external wastegate directly to the turbo. I decided im going to find a Exhaust Housing and use a Exhaust Flange for the Downpipe + External Wastegate.
