d16A1 obd0 to obd1 conversion questions
got a couple of ?'s about d16A1 obd0 to obd1 conversion.
1. will i have to change the dizzy, if so any idea of what dizzy to use, non-vtec
2. do i need to change the injectors
reason for the swap:
-keeping the stock d16A1 in my g1 teg getting ready for boost
-conversion to obd1 to so i can run hondata
-its cheaper than going zdyne and less technical than doing home tuning...
thanks in advance,
-euy
thanks in advance,
-euy
yes and yes.....thats the easiest way to do it......dont know if teggie obd0 harness plugs directly into obd1 computer though might have to do some re-wiring
thanks for the info. the obd1 ecu is not a direct plug in. i will be using a harness.
- will i need anything else with injectors? resistor box?
thanks again,
-euy
thanks again,
-euy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxjester »</TD></TR><TR><TD CLASS="quote">yes and yes.....thats the easiest way to do it......dont know if teggie obd0 harness plugs directly into obd1 computer though might have to do some re-wiring</TD></TR></TABLE>
Yes and NO. You will need to get the OBD1 distributor, but you will not need to change out the OBD0 injectors. My harnesses come with full detailed instructions for the install.
Jason
Jason
dr_latino999
236
Mar 28, 2020 12:34 AM
jacoblytle
Engine Management and Tuning
Jun 25, 2014 07:56 AM
