a/c hose insulation
Old Aug 3, 2004 | 01:07 PM
mozzy's Avatar
Default a/c hose insulation
My a/c takes a long time to cool. It takes atleast 20 minsto get comfortable inside. I checked the freon and the compressor and they both work fine.
While looking under the hood, I observed the a/c hose passes in front of the engine and there is a lot of hot air blowing onto the hose. I see this hose is well insulated but I still have 2 questions.
1. Can I redirect the a/c hose so that it is cooler and more efficiet?
2. Would it help if I wrap another layer of insulation on it?
Or do you guys have any other suggestions?
Thnxs
Old Aug 3, 2004 | 01:09 PM
mozzy's Avatar
Default Re: a/c hose insulation (mozzy)
Sorry forgot to mention-
93 LX-110k
Old Aug 3, 2004 | 04:21 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mozzy &raquo;</TD></TR><TR><TD CLASS="quote">1. Can I redirect the a/c hose so that it is cooler and more efficiet?
1. Yes, but it wont help anything.
2. No
Old Aug 3, 2004 | 04:30 PM
The_Todd's Avatar
Farts in the shower
Default Re: a/c hose insulation (Chiovnidca)
My guess as to why it won't cool is the lack of freon or r134a.
Run a pressure and coolant test
Old Aug 3, 2004 | 04:58 PM
2+2=5's Avatar
Default Re: a/c hose insulation (VRDrvr)
coolant test??
check the pulley belt, use leak detecting dye for leak.
since you said the feron level is good, and compressor is working right.
lilshady6796
Jan 15, 2009 11:02 PM
hotrod99
Jul 21, 2008 03:47 PM
Hondatuner88
Welding / Fabrication
Feb 13, 2008 06:56 PM
floatfisher
Apr 20, 2007 08:32 PM
Tizight
Nov 19, 2006 02:25 PM
