compressor surge ?
Old Jul 21, 2008 | 10:00 AM
hotrod99's Avatar
Default compressor surge ?
well a few weeks ago my bov stop working,took it to my tuner and there ended being a hole in the vaccum line,well they put a new hose on and I drove it home but now it has major compressor surge...when i got home i popped the hood and i notice they put a smaller sized hose on the bov...would this be the reason why it has compressor surge?
Old Jul 21, 2008 | 12:24 PM
hotrod99's Avatar
Default Re: compressor surge ? (hotrod99)
anyone have any input?
Old Jul 21, 2008 | 01:59 PM
tony413's Avatar
why havent you tryed just running a large hose to eliminate your question ?
Old Jul 21, 2008 | 02:03 PM
HONDACIVC93's Avatar
line qould be getting kinked or blocked or something. go toa hardware store, spend .60 on likr 5 feet of vaccum hose and try again.
Old Jul 21, 2008 | 02:04 PM
hotrod99's Avatar
Default Re: (tony413)
i dont have time to do it today,but i will go out tommorow and get a bigger diameter hose and see if that works...just seeing if anyone knew if a smaller hose would cause that issue
Old Jul 21, 2008 | 02:21 PM
tony413's Avatar
whats the pressure ratings of the hose surely they should not be caving-in
Old Jul 21, 2008 | 02:56 PM
champLSinteg's Avatar
If its a thin hose the engines vacuum is probably making it collapse shut.
Old Jul 21, 2008 | 03:00 PM
hotrod99's Avatar
Default Re: (champLSinteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by champLSinteg &raquo;</TD></TR><TR><TD CLASS="quote">If its a thin hose the engines vacuum is probably making it collapse shut.</TD></TR></TABLE>
I think your right because i dont even hear the bov at all its just a loud fluttering sound
Old Jul 21, 2008 | 03:12 PM
bigD's Avatar
Not to thread jack but picked up some hose from a local store and didnt notice untill I got home they gave me fuel line instead of vac lines, they do seem softer than normal vac lines. anyone use these without a problem?
Old Jul 21, 2008 | 03:47 PM
tony413's Avatar
Default Re: (bigD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigD &raquo;</TD></TR><TR><TD CLASS="quote">Not to thread jack but picked up some hose from a local store and didnt notice untill I got home they gave me fuel line instead of vac lines, they do seem softer than normal vac lines. anyone use these without a problem?</TD></TR></TABLE>
call your hardware store and asking for the collapse pressure of the hose or look on the side of the hose
HndaOwner
Mar 8, 2016 04:14 PM
rick_rabies
Apr 6, 2009 12:04 PM
rac3rb0i
Aug 22, 2004 10:06 AM
Mike banX
Jun 10, 2004 03:34 AM
