Polished valve cover how ?
Old Nov 28, 2001 | 03:10 PM
BoM's Avatar
BoM
Default Polished valve cover how ?
i was wondering if theres a special paint or sumthing to do this?
hahah i never seen that, theres a guy under the engine in the second picture hahaha, i think thats ek
[Modified by BoM, 7:11 PM 11/28/2001]
Old Nov 28, 2001 | 03:54 PM
immortal's Avatar
Banned
Default Re: Polished valve cover how ? (BoM)
take it to a shop that does polishing
its basically buffing the **** out of it with certain compounds and ****
Old Nov 28, 2001 | 04:13 PM
BoM's Avatar
BoM
Default Re: Polished valve cover how ? (immortal)
what kinda shop does polishing? what do i look up in the yellow pages?
Old Nov 28, 2001 | 08:04 PM
VTEC-LesS's Avatar
i'm not sure if the 2nd pic is polished. looks like he just sprayed aircraft remover to take off the paint. if you wanna do it yourself it'll take a damn long time. after the paint is off sand it down with 1000 or 2000 grit and use a polish compound afterwards.
Old Nov 29, 2001 | 04:15 AM
BoM's Avatar
BoM
Default Re: Polished valve cover how ? (VTEC-LesS)
thanks thats what i was looking for, self polishing,
unless the powder coating cost over 50 bucks i won't do it..
Old Nov 29, 2001 | 10:09 AM
jamal-188's Avatar
yeah, it takes hella long to polish it yourself. Start w/ a real course paper then work your way down. I'd wet sand it. You'll never be able to do it in one sitting, your damn arm will fall off. I though about buying a second one and just working on it like a couple hours a week until I was done.
Old Nov 29, 2001 | 10:47 AM
mad skillz's Avatar
New User
http://www.metalworks.com/Polish/PolishE&S.htm
Check this out....
Old Nov 29, 2001 | 10:51 AM
redteg1's Avatar
Default Re: Polished valve cover how ? (mad skillz)
hehe loox just like the valve cover that hand is rubbing on that clip for the new movie "the fear of speed"
Old Dec 4, 2001 | 11:10 AM
bigTom's Avatar
Default Re: Polished valve cover how ? (redteg1)
i may be wrong... but the first one looks polished and then chromed to me... the second is polished... but i took that picture when the motor was going in so no one was really paying attention to see if the valve cover was polished or not
Old Dec 4, 2001 | 03:07 PM
xivera's Avatar
Default Re: Polished valve cover how ? (ek9t)
Right, ek9t. The 1st one looks like triple plated chrome (normal finish, every shop does this. Just look for the better buy.) And, the other v.c. appears to be hand-polished. At any rate, if you wish to do it yourself all you have to do is go to Sears, buy a good rotary tool (very useful tool for other stuff) and get a polishing kit. For sure, that will cost less than $100 depending on the quality of the Dremel (rotary tool).
Old Dec 5, 2001 | 03:40 PM
ACURACY_VTEC's Avatar
New User
Default Re: Polished valve cover how ? (xivera)
what kind of turbo manifold is that in the 2nd pic?
Old Dec 5, 2001 | 05:45 PM
SpeedracerS4's Avatar
Default Re: Polished valve cover how ? (sweet-teg)
hmmm.....i wonder how are they going to fit the radiator and fan using that manifold?
Old Dec 11, 2001 | 06:17 PM
threatcon13's Avatar
New User
Default Re: Polished valve cover how ? (SpeedracerS4)
what kind of shop does polishing...what listing would it be under the yellow pages..thanks!
Old Dec 11, 2001 | 07:22 PM
BoM's Avatar
BoM
Default Re: Polished valve cover how ? (turbo01gsr)
try a powdercoating
i found a couple
went to yahoo.com, check the yellow pages, and found one 2miles away from my crib, but i just did my own work to practice and help my friends polish stuff
Old Dec 11, 2001 | 11:54 PM
Charles B.'s Avatar
If u wanna just take the black stuff off of your valve cover you can use JASCO or any other strong paint thinner. My cousin did it on his old ZC valve cover and we did the same thing to my uncle's GSR valve cover. You can buy that stuff at like home depot. It wont give you a "polished" look, but rather just a plain silver greyish look. Sorry I have no pix.
Old Dec 14, 2001 | 06:00 AM
kranked91dx's Avatar
I did mine my self, can send pics if you want, the basic, is to first remove all paint, usine, thinner, brake cleener, or oother strong thing, then sand it up with 1000, then goes in lower range of paper, like 2000, or 1500, then get on compound, and RUB LIKE HELL!!!, after, just, put a gentle coat of clear onit to avoid aluminium oxidation!!! tadam,
Old Dec 14, 2001 | 07:26 AM
Dido-Motosports's Avatar
New User
Check out http://www.jet-hot.com for more info. on this type of stuff. There really close to you as well, in Bridgeport, PA (outskirts of Philly).
Old Dec 14, 2001 | 07:43 AM
FifthGearOnline's Avatar
check out this its at http://www.jdmfan.com http://www.jdmfan.com/technical/cosm...sh_valvecover/
JDM_902
28
Mar 7, 2008 01:14 PM
xxxmikenicexxx
Jul 25, 2005 08:57 AM
jsteezy1290
18
May 12, 2004 08:59 PM
.RJ
Apr 28, 2003 07:14 PM
hi mom
Mar 8, 2003 01:05 PM
