H22 STOCK LSD INSIDE A H23 TRANSMISSION? TO BE OR NOT TO BE?
Old Aug 3, 2004 | 01:31 AM
h22turbocivic4dr's Avatar
Default H22 STOCK LSD INSIDE A H23 TRANSMISSION? TO BE OR NOT TO BE?
HEY GUYS, QUICK QUESTION, I HAVE AN H22 TURBO IN A 4DR '93 CIVIC WITH AN H23 TRANS, AND CAME ACROSS A STOCK H22 LSD, JUST THE DIFF. IF I OPEN MY BELL HOUSING AND PULL MY OUT MY NON LIMITED SLIP DIFFERENTIAL CARRIER AND FINAL DRIVE, AND PUT IN THE H22 LSD, WILL IT WORK? ONLY RESPOND IF YOU KNOW THIS IS POSSIBLE OR ISN'T, OR HAVE PERTANENT INFORMATION PROVING IT CAN OR CAN'T BE DONE. THANKS.
Old Aug 3, 2004 | 01:37 AM
satan_srv's Avatar
Default Re: H22 STOCK LSD INSIDE A H23 TRANSMISSION? TO BE OR NOT TO BE? (h22turbocivic4dr)
if it's the m2b4 lsd I would say no it's a different size than other h22a diffs you can't even put an aftermarket lsd in there.
don't cheap out just buy a real Lsd like a quaife and put it in the h23 tranny. the oem lsd is nothing special it barely works!
Old Aug 3, 2004 | 06:47 AM
LudeyKrus's Avatar
Why not just use the full LSD H22 tranny?
Old Aug 3, 2004 | 11:33 AM
95PreludeSi's Avatar
Default Re: H22 STOCK LSD INSIDE A H23 TRANSMISSION? TO BE OR NOT TO BE? (satan_srv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by satan_srv &raquo;</TD></TR><TR><TD CLASS="quote"> the oem lsd is nothing special it barely works!
Is there anything wrong with the M2B4 LSD? I thought I heard it was good.
&lt;-doing research as to whether or not the M2B4 is worth it when I do my swap.
Old Aug 3, 2004 | 02:07 PM
Pat McGroin's Avatar
Default Re: H22 STOCK LSD INSIDE A H23 TRANSMISSION? TO BE OR NOT TO BE? (95PreludeSi)
M2b4 casing is totally different from the other H-F series trannies. I am kind of glad I didn't get the JDM lsd tranny with my swap.
Quaife
Old Aug 3, 2004 | 02:11 PM
Monkey Fing a Coconut's Avatar
Default Re: (LudeyKrus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeyKrus &raquo;</TD></TR><TR><TD CLASS="quote">Why not just use the full LSD H22 tranny?</TD></TR></TABLE>
he doesnt have the m2b4 tranny, just the lsd from inside it...
Old Aug 3, 2004 | 07:37 PM
satan_srv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95PreludeSi &raquo;</TD></TR><TR><TD CLASS="quote">
&lt;-doing research as to whether or not the M2B4 is worth it when I do my swap.</TD></TR></TABLE>
there is nothing special about it as far as I'm concerned....it's not liek an ITR OEM LSD it doesn't lock nearly as much
Old Aug 3, 2004 | 08:30 PM
Phat_Jax's Avatar
Default Re: H22 STOCK LSD INSIDE A H23 TRANSMISSION? TO BE OR NOT TO BE? (Pat McGroin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pat McGroin &raquo;</TD></TR><TR><TD CLASS="quote">M2b4 casing is totally different from the other H-F series trannies. I am kind of glad I didn't get the JDM lsd tranny with my swap.
Quaife </TD></TR></TABLE>
Please explain? I'm getting my swap soon and was hoping to get this tranny. If it's got problems I'd like to know why... thanks!
Old Aug 3, 2004 | 10:22 PM
Default Re: H22 STOCK LSD INSIDE A H23 TRANSMISSION? TO BE OR NOT TO BE? (Phat_Jax)
First, you can't buy a quaife for it. If you were to break the LSD you're gonna need to find another JDM LSD. Also, if the casing breaks (like my friend's) good luck searching for another case. There really aren't problems with it, it just has a couple of cons.
Old Aug 4, 2004 | 01:50 AM
grappler's Avatar
So a usdm 94 lude h22 tranny won't accept the jdm M2b4 lsd?
If so, thank everyone for the save!
Old Aug 4, 2004 | 06:57 AM
Thanx for the info. I was hoping to get a LSD with my swap, but it sounds like I would be better off getting a quaife. They are a little expensive, so I guess I will have to wait. Anyone have opinions on Kaaz or Phantom grip. I never have plans to do more than bolt-ons to the car.... 190-200whp would be the max the car would ever see. The car car will see street driving, autocrossing, and maybe the occasional track day.
Sorry to Hi-jack this thread.
Old Aug 4, 2004 | 01:06 PM
As far as the KAaz and phantom grip.
Phantom - Some swear it works, some swear it's the biggest POS. Too many mixed reviews to come to a decision.
Kaaz - Only downside is it is a clutch-type LSd which means it will require maintenance and a break in session of doing figure 8's in a parking lot. The amount of maintenance will depend on how often you go to the track. Also here's alittle something about the KAAZ. Scroll down to 1 2 NV's post on the first page (pics provided). https://honda-tech.com/zerothread?id=918902
Quaife - Warrantied for life, even under race conditions. Helical which means no breaking in and no maintenance, same system as OEM LSD's, but even stronger.
As far as an m2b4 LSD fitting into a USDM tranny, it won't fit to my knowledge. I know Satan_SRV tried to fit a quiafe into the M2B4 and it was not successful. If anyone knows anything else please chime in anytime. Please correct me if I am wrong since I do not want to be the bearer of misinformation.
Knightzero7
Transmission & Drivetrain
Apr 10, 2014 02:39 PM
SPRLude
Apr 26, 2006 03:24 AM
Kashi
Jan 18, 2005 11:03 AM
h22turbocivic4dr
Aug 5, 2004 08:41 PM
H22A EG6
Jun 2, 2004 08:28 PM
