Hard to start after letting the car sit...
Old Aug 2, 2004 | 11:08 PM
SivikHatch's Avatar
Default Hard to start after letting the car sit...
EK with built b18c1 motor...
Everytime I start my after leaving it off for around an hour top, I always have to crank my car then stop cranking and crank again making it start the moment i attempt the 2nd crank. What is causing it to do this?
I'm thinking this problem is also linked with why my car is bogging after 7 mins of driving at 50-60 mph... I would have to downshift to gain speed but then it gets worst until I'm in first gear and can't gain anymore speed. The more I attempt to accelerate it would bog even harder. I would have to pull over to let the car rest for 2 minutes until i can start it up again to go about another half a mile and rest it again. Also, gas mileage sucks too. How about a knock sensor causing it to bog? Correct me if my assumptions are wrong.
Modified by SivikHatch at 2:18 AM 8/3/2004
Old Aug 3, 2004 | 02:30 AM
speedymon's Avatar
Default Re: Hard to start after letting the car sit... (SivikHatch)
How's your 02 sensor readings? Maybe it responds slowly. Cap and rotor? Leaky wires? Fuel filter clogged?
As for starting difficulty, how bout main relay?
Old Aug 9, 2004 | 11:11 AM
SivikHatch's Avatar
Default Re: Hard to start after letting the car sit... (speedymon)
My o2 sensor is just hanging by the distributor since I don't have a O2 bung yet... but where is the main relay located so I can give it a test... 96 civic with b18c1 and b18c5 ecu...
Old Aug 10, 2004 | 12:04 AM
PnX-R's Avatar
[QUOTE=SivikHatch] I would have to pull over to let the car rest for 2 minutes until i can start it up again to go about another half a mile and rest it again.
Sounds like the work of the infamous PGM-FI Main Relay..
As for the long cranking after an hour pit stop, I'd try turning the key to the ON position for two seconds, then to the OFF position, and back to the ON position for two seconds. Then I would turn the key to START. If the car starts after two or three turns, I would say that fuel isn't staying in your fuel lines. And I believe, but can't remember, the problem is your fuel pressure regulator..
Old Aug 11, 2004 | 11:19 PM
SivikHatch's Avatar
Default Re: Hard to start after letting the car sit... (PnX-R)
I'll check up on the main relay.
You mean my fpr could be faulty or my settings I have could be wrong?
Old Aug 12, 2004 | 12:05 AM
untuned's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SivikHatch &raquo;</TD></TR><TR><TD CLASS="quote">My o2 sensor is just hanging by the distributor since I don't have a O2 bung yet</TD></TR></TABLE>
that would be your driveability problem..
turnsignalandy
Nov 10, 2012 04:56 AM
mc_civic213
Jun 23, 2008 05:58 AM
xxmastermindxx
Dec 7, 2006 03:54 PM
lutz707920
Mar 28, 2006 01:41 PM
yusoslo
Sep 28, 2003 12:29 PM
