differences between h23 and f22b dohc?????????
Old Aug 2, 2004 | 06:01 PM
vteckilla7's Avatar
Default differences between h23 and f22b dohc?????????
Ok got my motor in and running today, halfway, but its starts, anyway, i noticed a bunch of different sensors, one towards the bottom above oil pan, and one under the intake manifold, im guessing oil pressor sensor, and knock sensor, can someone help me out????
Old Aug 3, 2004 | 11:52 AM
prelittlelude's Avatar
Default Re: differences between h23 and f22b dohc????????? (vteckilla7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vteckilla7 &raquo;</TD></TR><TR><TD CLASS="quote"> Ok got my motor in and running today, halfway, but its starts, anyway, i noticed a bunch of different sensors, one towards the bottom above oil pan, and one under the intake manifold, im guessing oil pressor sensor, and knock sensor, can someone help me out????</TD></TR></TABLE>
well the oil press sender is usually in a different location than that of the H series, and im not sure if its going to have a kncok sensor seeing as how its a f series motor,
edit: also irrelevent to the question , the bore is different, with only a 85mm bore, just for furture refrence
Old Aug 3, 2004 | 12:32 PM
Sam1am26's Avatar
Default Re: differences between h23 and f22b dohc????????? (prelittlelude)
It is probably the oil pressure switch... the f22b dohc block is so similar to the h23 excpet for the bore anyways...
Old Aug 3, 2004 | 06:45 PM
vteckilla7's Avatar
Default Re: differences between h23 and f22b dohc????????? (Sam1am26)
am I ok not using that???, the f22 does not have one, I took the one off the h23 and it's tapped into the block, yes it is an oil pressure something, oil came out.
h22_crx
Jan 19, 2007 03:06 PM
Attaus
Jan 4, 2007 08:26 AM
89civicdxracer
10
Jan 14, 2005 11:05 AM
oemDC2
Apr 28, 2004 09:37 PM
oemDC2
Apr 28, 2004 09:19 PM
