rear disc brake help
I know i need the trailing arm and most of the stuff off the rear of the integra. What else do i need and what year do I need to use i have a 92 hatch vx
If i need the master cly. can i just use a 92 civic si master and do i need to upgrade my booster because it is not abs and i really dont want to upgrade my booster
Any help please thanks
integra trailing arms.
integra rs mc/bb combo and 4040 ppv.
lcas (if you want to mount a sway bar on later).
ebrake cables.
btw: heres my how-to https://honda-tech.com/zerothread?id=812062
ebrake cables.
actually you dont need integra rs master cyl. or booster just get the 90-91 civic ex with all wheel disc brake master cylinder and the prop valve with everything else listed above and ur good to go with the civic master cyl. u dont need the booster or to bend lines its a complete bolt on.
Check out this thread ...it will help a lot when it comes to a few things....https://honda-tech.com/zerothread?id=954203 Good luck
solis153
Suspension & Brakes
Mar 8, 2012 02:23 AM
swallow
11
Aug 7, 2010 09:14 PM
whole9
10
Mar 30, 2007 10:00 PM
i did rear disk conversion...is integra brake master cylinder 7/8 good enough?..and wat emergency ca
fastest
Jun 9, 2004 08:54 PM
