rear disc brake help
I know i need the trailing arm and most of the stuff off the rear of the integra. What else do i need and what year do I need to use i have a 92 hatch vx
If i need the master cly. can i just use a 92 civic si master and do i need to upgrade my booster because it is not abs and i really dont want to upgrade my booster Any help please thanks |
Re: rear disc brake help (b204d)
integra trailing arms.
integra rs mc/bb combo and 4040 ppv. lcas (if you want to mount a sway bar on later). ebrake cables. btw: heres my how-to https://honda-tech.com/zerothread?id=812062 |
Re: rear disc brake help (=GAMEOVER=)
thanks man
actually you dont need integra rs master cyl. or booster just get the 90-91 civic ex with all wheel disc brake master cylinder and the prop valve with everything else listed above and ur good to go with the civic master cyl. u dont need the booster or to bend lines its a complete bolt on.
Re: rear disc brake help (LSVTEC91)
thank you for the help i heard that u can use that mc but did not know about the prop v. thanks
Check out this thread ...it will help a lot when it comes to a few things....https://honda-tech.com/zerothread?id=954203 Good luck https://honda-tech.com/forums/images/smilies/emthup.gif
you also need the rear brake lines (soft) from a rear disc EG or integ
