P30 or P28?
Old Aug 2, 2004 | 12:21 PM
EFin' Kyle's Avatar
Default P30 or P28?
this may be a stupid question but i am new to electronics on cars. i was wondering what is the difference between a p30 and p28 ecu. aren't they both off of a del sol with a b16 or no? i need one or the other to put in my crx with a b16a1. which should i get?
Old Aug 2, 2004 | 12:23 PM
4drEF's Avatar
Keyboard Humorist
Default Re: P30 or P28? (crxstreetracer90)
I dont think the P28 came with the B16 del sol.
Old Aug 2, 2004 | 12:24 PM
EFin' Kyle's Avatar
Default Re: P30 or P28? (4drEF)
what did it come with?
Old Aug 2, 2004 | 12:28 PM
CRX T-Si's Avatar
Unless you have or will convert to OBD1 then neither will work for you.
Anyways here is your answer, as simple as it can be. The p30 is the DelSol ecu for the B16 motor. That ecu has the Knock sensor input and it's programmed for the B16.
Where as the p28 is for the SOHC Vtec motor, this one does not have the knock sensor input. And it's programmed for the SOHC motor.
People(like myself) get the p28 cause there is alot out there then p30. You just rechip the P28 and it would work the same minus the knock sensor.
But in your case, your car is OBD0 so unless your going to OBD1 then you need to get a PR3 or PW0 ecu for you applications.
EFin' Kyle's Avatar
oh okay. thanx man. im glad i didnt go buy one.
Old Aug 2, 2004 | 12:30 PM
4drEF's Avatar
Keyboard Humorist
I think the P28 was the SOHC VTEC motors and the P30 is the B16 one.
If you are going to get the swap sticker at the ref, then go for the P30 which I believe matches the B16 motor.
If not, then just get a P28 which is probably going to be easier to find and probably cost a little less.
Both are chippable as far as I know.
SETI20
Aug 17, 2004 11:57 AM
skribblah
Jul 11, 2003 10:17 AM
B16EJ
Jun 26, 2003 08:58 AM
B16EJ
Jun 25, 2003 08:04 AM
sirminder
May 24, 2002 06:16 PM
