where can i buy a lighten flywheel for a 1995 single vtec motor
Old Aug 2, 2004 | 11:07 AM
racingant's Avatar
Default where can i buy a lighten flywheel for a 1995 single vtec motor
where can i buy it from plesae help
Old Aug 2, 2004 | 11:27 AM
temp's Avatar
Default Re: where can i buy a lighten flywheel for a 1995 single vtec motor (racingant)
http://www.clutchcityonline.com
Old Aug 2, 2004 | 11:42 AM
racingant's Avatar
Default Re: where can i buy a lighten flywheel for a 1995 single vtec motor (temp)
bump
Old Aug 2, 2004 | 12:01 PM
Deemeetree's Avatar
Electrician
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by temp &raquo;</TD></TR><TR><TD CLASS="quote">http://www.clutchcityonline.com</TD></TR></TABLE>
Old Aug 2, 2004 | 12:04 PM
bob barker's Avatar
https://honda-tech.com/zerothread?id=919537
Old Aug 2, 2004 | 12:05 PM
Draggin99Si's Avatar
Default Re: where can i buy a lighten flywheel for a 1995 single vtec motor (11-bravo)
i got mine at turboevolution.com
Old Aug 2, 2004 | 01:11 PM
owen_the_soyboy's Avatar
the stock 92-95 civic cx flywheel is lighter than the vtec flywheel by a few pounds.
Old Aug 2, 2004 | 05:07 PM
temp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 11-bravo &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=919537</TD></TR></TABLE>
aluminum for a flywheel is bad bad
Old Aug 2, 2004 | 05:14 PM
XRacerX's Avatar
I got a stock lighten one (10lbs) from a local shop IMPORTPOWERHOUSE.
Try your local shop first.
Old Aug 2, 2004 | 05:17 PM
temp's Avatar
Default Re: where can i buy a lighten flywheel for a 1995 single vtec motor (XRacerX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XRacerX &raquo;</TD></TR><TR><TD CLASS="quote">I got a stock lighten one (10lbs) from a local shop IMPORTPOWERHOUSE.
Try your local shop first.</TD></TR></TABLE>
thats even worse then aluminum........you do know that everytime you drive your car you are putting your life in jeopardy with that flywheel in your tranny right?
Boostage
Jul 5, 2007 03:01 PM
IntegR
Jan 28, 2007 07:35 AM
roadrunner
Feb 15, 2006 04:54 AM
884door
Apr 3, 2005 03:39 PM
mrx
Oct 1, 2004 11:17 AM
