Stock Oem airbox with Fake J's arm??
Old Aug 2, 2004 | 03:46 AM
cnyej1's Avatar
Default Stock Oem airbox with Fake J's arm??
Ok ive heard of people doing the oem airbox with like an AEM ram air arm.....but many have come to the conclusion that J's performs better.... so would it not make sence to put a J's arm on an OEM airbox?? Has this been tried? I did the search but after going back about 3 pages I figured I had seen enough... hehe..
Old Aug 2, 2004 | 04:47 AM
jerbear!'s Avatar
dont u think itll be kind of a waste? cuz then u would have to go out and buy a k&n drop in and would have to do a bunch of pointless work that does hardly anything just for the "clean" look.
Old Aug 2, 2004 | 04:48 AM
menkio's Avatar
Default Re: Stock Oem airbox with Fake J's arm?? (cnyej1)
.. thats pointless.
Old Aug 2, 2004 | 06:59 AM
rodrez.'s Avatar
The inlet on the J's intake is huge, probably bigger than the height of the box itself. Also there's the factor of space under the hood.
Old Aug 2, 2004 | 07:02 AM
Deemeetree's Avatar
Electrician
Indeed. Have you measured the diameter of the inlet on the pipe. I used to have it. Seriously, my arm fit into it kinda snug which means the pipe is VERY large. We use short-ram piping like the (eBay or AEM) kind because you can adapt it to the airbox easily since the inlet diameter is roughly the same size + - as the OEM airbox outlet.
Old Aug 2, 2004 | 07:38 AM
hayabusa160's Avatar
wont work because of the size of the j's intake. im sure it wont help either kill flow if anything.
if you want to try something that might work make a velocity stack thats sized to the j's intake
Old Aug 2, 2004 | 10:05 AM
ek9800's Avatar
Default Re: Stock Oem airbox with Fake J's arm?? (hayabusa160)
J's intake arm is to big and its pointless
Modified by jdm98hb at 3:41 PM 8/5/2004
Todd00
17
Oct 22, 2015 03:26 PM
B00stedEh3
Mar 24, 2011 06:40 PM
YoungKadafi
71
Jan 25, 2007 02:31 PM
wrXtian
Mar 1, 2005 07:08 PM
