Amplifier power wire help
Hi, I would like to install an amp in my 93 mude,I would like to know if I have to make a hole for the power cable or is there already a hole that I can use for a 4 gauge cable.
Thanks
Thanks
I still don' t know where there' s a hole I can use, is there one that has an easy access on both side of the firewall, looks like there' s a hole behind the fuse box on the passenger side but don' t know where it goes out inside of the car. it' s behind the dash, it also require to remove the fuse box and then the dash.
I' m looking for a hole that is easily accessible from both side, or at least 1 side.
PLEASE tell me where it is. There shoulb be one person who have install an amp using an existing hole.
if you pull back the carpet behind the clutch, there might or might not be some padding, if so behind it is a whole exactly big enough for a 4 gauge wire to fit through in the ipper left corner of the floor board of the drivers side. hope that helps
benzo_tek
Sep 22, 2008 02:56 PM
Takumi Fujiwara
Audio / Security / Video
13
Aug 3, 2006 11:40 AM
