Bixenon HID swap...
Old Aug 1, 2004 | 06:52 PM
BROCiviC's Avatar
Default Bixenon HID swap...
Just a few pics of my newest project... I'll have some nice beam shots up here sooner or later let me know what you guys think!
Old Aug 1, 2004 | 07:03 PM
North_Texas's Avatar
Default Re: Bixenon HID swap... (BROCiviC)
Well seeing you have no tech behind your HID thread. WHO CARES!
Old Aug 1, 2004 | 07:10 PM
JDMFreak's Avatar
Default Re: Bixenon HID swap... (dixieR3dneck)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dixieR3dneck &raquo;</TD></TR><TR><TD CLASS="quote">Well seeing you have no tech behind your HID thread. WHO CARES!</TD></TR></TABLE>
not to be rude but you been here longer then that, you dont need to leave a remark like that...that kinda mean...
i like the HID retrofit, please do show me or us some beam pattern!
Old Aug 1, 2004 | 07:12 PM
skip.two's Avatar
looks nice, but this should belong in the Appearance / Cosmetic forum.
https://honda-tech.com/zeroforum?id=28
Old Aug 1, 2004 | 08:14 PM
BROCiviC's Avatar
Default Re: Bixenon HID swap... (JDMFreak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMFreak &raquo;</TD></TR><TR><TD CLASS="quote">not to be rude but you been here longer then that, you dont need to leave a remark like that...that kinda mean...
best thing about it is I've been around here longer than he has... I just don't want to consider a lighting setup like this only for appearance/cosmetic because that's not why I did it in the first place sorry I posted here anyway
oh and by the way the tech is the same as every other HID setup in an EK Civic or any other car for that matter...
Old Aug 1, 2004 | 10:31 PM
Default Re: Bixenon HID swap... (jL iLLuZiOnz 9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jL iLLuZiOnz 9 &raquo;</TD></TR><TR><TD CLASS="quote">looks nice, but this should belong in the Appearance / Cosmetic forum.
https://honda-tech.com/zeroforum?id=28</TD></TR></TABLE>
I'm finally going to have to agree with the so called "helper". There is no tech behind these post so why post it in here. You didn't even say what you did or how you did whatever. Just if they look good. So once again I say, "Who Cares."
Old Aug 1, 2004 | 11:47 PM
JDM R's Avatar
let us know how you did it, do a write up
Old Aug 2, 2004 | 09:44 AM
Hood's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dixieR3dneck &raquo;</TD></TR><TR><TD CLASS="quote">There is no tech behind these post so why post it in here. You didn't even say what you did or how you did whatever. Just if they look good. So once again I say, "Who Cares."</TD></TR></TABLE>
so your posts are helping?
OP: looks good man.
(just post in the correct forum next time )
Old Aug 2, 2004 | 07:01 PM
BROCiviC's Avatar
Default Re: Bixenon HID swap... (Hood)
Here's the beam pattern shots, although kinda shitty, I bent the shields of the projectors to give the cutoff a more blueish appearance instead of the ugly mustard yellow the normal A6 projectors put out. That was a pretty simple process which I'll explain briefly for the sake of not getting bitched at
Just bend the shields with your fingers or a pair of pliers... for the bixenon shield as in this case you must bend both the stationary shield and the moving part or the headlights will not switch to highs as the shield will sieze up. The beam pattern needs adjusted but I forgot my long screwdriver at home and I'm at my apartment now so... until next time...
by the way the wall is approx. 35 to 40 feet from the car and there's a slight ridge in the parking lot blocking some of the roadway illumination creating the dark spot after the first set of parking spots.
cheers
the1
Jan 24, 2007 03:48 PM
shift6th
Honda S2000
Apr 13, 2004 03:49 AM
TurbothisLS
Mar 18, 2003 01:50 PM
swlabhot
Feb 7, 2003 12:14 PM
