need help guys car won't start
ok i was driving on the highway last night. i was in 4th gear and i thought i was in 3rd for some reason and shifted down to 2nd gear. the car screamed loud so i pulled over everything was ok but the dist was making noise. so i started driving and ignored it like a $%$% and went home, next day i drove to nj and on the highway dist started to get louder than car started to bog out and than it cut off, i pulled over took my dist cap off and the rotor fall right out so i took a gsr dist right out a running gsr and put it on and now it cranks but don't crank and start, so the next day i changed the spark plugs and wires cause they were black and rustie cause i swapped the motor in a week ago. it's a 94 cx hatch wit a jdm b16 2nd gen... i was using the dist and plugs and spark plugs from japan cause i never got to change them....so now car still not starting but it cranks, i also put a new starter and alt in. i donno wat it is guys,, i got power and fuel pump turns on i don't get it wat else can go if the dist goes...please help i need the car for work
Modified by NYCFINESTEG at 3:46 AM 8/2/2004
EcivicG
20
Aug 11, 2008 06:09 PM
Bloody Hatch
Apr 29, 2008 07:01 PM
