need help guys car won't start
Old 08-01-2004, 06:26 PM
NYCFINESTEG's Avatar
Default need help guys car won't start
ok i was driving on the highway last night. i was in 4th gear and i thought i was in 3rd for some reason and shifted down to 2nd gear. the car screamed loud so i pulled over everything was ok but the dist was making noise. so i started driving and ignored it like a $%$% and went home, next day i drove to nj and on the highway dist started to get louder than car started to bog out and than it cut off, i pulled over took my dist cap off and the rotor fall right out so i took a gsr dist right out a running gsr and put it on and now it cranks but don't crank and start, so the next day i changed the spark plugs and wires cause they were black and rustie cause i swapped the motor in a week ago. it's a 94 cx hatch wit a jdm b16 2nd gen... i was using the dist and plugs and spark plugs from japan cause i never got to change them....so now car still not starting but it cranks, i also put a new starter and alt in. i donno wat it is guys,, i got power and fuel pump turns on i don't get it wat else can go if the dist goes...please help i need the car for work
Modified by NYCFINESTEG at 3:46 AM 8/2/2004
NYCFINESTEG is offline
Old 08-01-2004, 06:36 PM
Electrician
Deemeetree's Avatar
Please edit that sentence and use paragraphs with complete sentences and punctuation.
Deemeetree is offline
Old 08-01-2004, 06:57 PM
Default Re: need help guys car won't start (NYCFINESTEG)
get a distubutor for a b16a
mbdelsol is offline
Old 08-01-2004, 07:09 PM
Default Re: need help guys car won't start (mbdelsol)
wats the diff i just got this one brand new?????? it gotta be something else anybody....??
Old 08-01-2004, 08:08 PM
FwdCivicHatch's Avatar
Make sure you have the right OBD dist. also do you have any codes from your ECU. If not that's why you put new plugs in you JDM rusty motor
FwdCivicHatch is offline
Old 08-01-2004, 10:05 PM
hatchi's Avatar
have you checked all your fuses?? any chance you putting the timing order wrong?? all plugs gapped correctly?
hatchi is offline
joeroberts1984
12-19-2013 06:32 PM
EcivicG
20
08-11-2008 06:09 PM
JsSIR
06-25-2008 06:43 PM
Bloody Hatch
04-29-2008 07:01 PM
lean
05-16-2005 06:05 PM
Quick Reply: need help guys car won't start
  • Ask a Question
Question Title:
Description:
