97 Boosted Civic EX Compressions Test, Is Motor Doomed???
Old Jul 31, 2004 | 10:11 PM
civicshowracing65's Avatar
Default 97 Boosted Civic EX Compressions Test, Is Motor Doomed???
I was wondering if you guys could help me with the problem i have. I just did a compression test on my 97 turbo civic ex and here were the numbers...
Cylinder #1 - 190
Cylinder #2 - 195
Cylinder #3 - 190
Cylinder #4 - 203
In my haynes manual it says stock is suppose to be 184psi with a variance of +-24
203 is getting close to the max variance
Can anything be done to help cyclinder #4 to bring it back down? Seafoamed it 2 weeks ago but only use a 1/3 of the can, was i suppose to use the whole can?
Or is my motor just going unless I change out the pistons and rods to handle the boost?
My setup:
15g greddy kit
type 31 fmic
msd wires
ngk 1 step colder plugs (looks kinda ashy in color???)
lucas 440cc injectors
afc hack
aem pulleys
turboxs dual stage boost controller
any help would be great because if my motor is doomed, i'm not going to buy a new clutch and flywheel. Just save to swap motor
Old Jul 31, 2004 | 10:15 PM
hondaeg8's Avatar
Default Re: 97 Boosted Civic EX Compressions Test, Is Motor Doomed??? (civicshowracing65)
the numbers aren't that far off from each other though.
what is seafoam and what is it supposed to do?
Old Jul 31, 2004 | 10:17 PM
ABK's Avatar
ABK
Default Re: 97 Boosted Civic EX Compressions Test, Is Motor Doomed??? (hondaeg8)
did you discharge the fuel system, or you could of also just cranked it one time to many. There is no such thing as higher compression number then stock unless you touched the internals.
Old Jul 31, 2004 | 10:19 PM
hondaeg8's Avatar
Default Re: 97 Boosted Civic EX Compressions Test, Is Motor Doomed??? (ABK)
i thought you couldn't over crank it. you just crank it until the pressure doesn't rise anymore.
Old Jul 31, 2004 | 10:29 PM
i just cranked it 10 times each cylinder.
no i did not discharge the fuel system, i just simply removed the 15a fuse from the fuse box in the engine bay. What do you mean by discharge the fuel system? Opening gas cap? Or actually disconnecting at the fuel filter?
Modified by civicshowracing65 at 7:41 AM 8/1/2004
Old Jul 31, 2004 | 10:37 PM
hondaeg8's Avatar
was that the ecu fuse?
Old Jul 31, 2004 | 10:56 PM
ABK's Avatar
ABK
take out the fuse from the fuel pump and ret the engine run until it dies.
Old Jul 31, 2004 | 11:34 PM
yes did that. But the question at hand is how to fix the problem and whether it is fixable? thanks
Old Jul 31, 2004 | 11:46 PM
hondaeg8's Avatar
what is seafoam??
also...maybe you have a shitty compression tester. i would try it again and see what happens.
Old Aug 1, 2004 | 12:39 AM
civtegra_hybrid's Avatar
wrong, sorry buddy. after the eng. is lubed up. (crank it a faw times or untell it's lubed) you can tell if it's lubed or not buy putting the psi tester on the #1 cyl. and crank it up untel it hits 200 or 180, and then reset it. crank it over it sould pump three times, at the thired time, thats your psi. keep the psi the same for like ten sec. it should hold that psi. if the rings are good. if you notice if you just keep cranking it will keep going up. O yeah and just to let you know a motor will run on 80psi. lol so keep that in mind do this to all the cyl. good luck, O yeah what's your boost and how meny miles on that eng. ????
Old Aug 1, 2004 | 12:50 AM
hondaeg8's Avatar
Default Re: 97 Boosted Civic EX Compressions Test, Is Motor Doomed??? (civtegra_hybrid)
3 times....are you kiding me?
http://www.c-speedracing.com/h...t.php
Modified by hondaeg8 at 10:05 AM 8/1/2004
Old Aug 1, 2004 | 01:18 AM
hondaeg8's Avatar
http://www.seafoamsales.com/motorTuneUpTechGas.htm
it says it increases your compression...maybe thats why your numbers are high :dunno:
Old Aug 1, 2004 | 03:22 AM
7808's Avatar
seafoam is made of seafoam near radioactive waste dumps and it makes you car fuckinfast.
Old Aug 1, 2004 | 05:54 AM
right now i'm running 5.5psi half the time and at night 10 psi. My motor has 85k on it. I was just wondering because lately my car has been running like *** going up hill and was wondering if this was the problem. Am I really cranking it too long? I thought it says to keep cranking til it can't go anymore
Old Aug 1, 2004 | 10:31 AM
anyone can tellem me if my motor is headed for death?
Old Aug 1, 2004 | 08:00 PM
ABK's Avatar
ABK
redo it just this time crank it 5 times
and then you will know
Old Aug 1, 2004 | 08:10 PM
yeah jack, first see if you have any blow by. start your car and take off the oil cap, and see if smoke come's out, and if it does, then your rings are gone. then how meny miles do you have on it ??? and just to let you know that's three times after it's lubed up, that means you have to crank it for a while to lube it, and then reset the gauge, then when you crank it it should jump higher, and only take Three or fourth the most. to bring it up to the spec. that it's at.
Lee Williams
Nov 24, 2014 08:18 AM
sjracer
26
Aug 1, 2013 09:42 PM
10sec4door
Apr 20, 2010 11:01 AM
BoostedGSRBubble
May 21, 2003 07:48 PM
CiViCeKdRiVeR47
May 21, 2003 01:17 AM
