AFC Hack Check Engine Codes
Those with the f23, does anyone get the check engine light often? I'm getting 3 everytime boost builds. The codes are:
Mass Airflow sensor
Running Too Rich
Cant remember the last one.
I will try and get the exact codes tomorrow when I go to get them cleared again.
Today, code P1106 "Fuel Air Metering" was read today. Whats up?
Only running 6lbs, and it has been tuned.
Modified by jmal1919 at 3:08 PM 8/1/2004
Mass Airflow sensor
Running Too Rich
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jmal1919 »</TD></TR><TR><TD CLASS="quote">Those with the f23, does anyone get the check engine light often? I'm getting 3 everytime boost builds. The codes are:
Mass Airflow sensor
Running Too Rich
wait, f23's use a MAF instead of a MAP? are you sure about this?
Mass Airflow sensor
Running Too Rich
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Atheist »</TD></TR><TR><TD CLASS="quote">Nope, I get none on my f22. What #s are you running? </TD></TR></TABLE>
bout -35%
Modified by jmal1919 at 10:29 AM 8/2/2004
bout -35%
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nick H »</TD></TR><TR><TD CLASS="quote">wait, f23's use a MAF instead of a MAP? are you sure about this?</TD></TR></TABLE>
pretty sure, but will write them down today.
im pretty sure you have a MAP sensor. how much boost are you running? because anything over 11 lbs through the stock MAP sensor will throw a CEL. have you had the AFC tuned yet? if not, you might wanna throw it on the dyno and hook it up to a wideband to get some accurate A/F ratio numbers.
kaoss_11
Sep 10, 2006 04:14 PM
kaoss_11
Sep 10, 2006 12:03 AM
