Is This Engine Swap Good For A Sedan???
Would A Sedan Run Good If I Ran A B16 SOHC Vtec In It, and eventually turbocharged it???
there is aftermarket supports for a SOHC 1.6 Vtec Right?
you might want to put a flame suit on. there is no such thing as an SOHC B16. all of the B series motors are DOHC. do some more searching and you'll learn all kinds of good stuff. oh, and the aftermarket is huge fore the b16.
unless you mean D16 then yea that is not a bad idea...i seen some D16 Turbocharged push out some good numbers...but yes becareful what you type you will be flamed...B-series and SOHC dont mix hehe
