warranty<<<>>>exhaust
Old Nov 27, 2001 | 09:15 PM
gmsu00's Avatar
New User
Default warranty<<<>>>exhaust
aftermarket exhaust will avoid my warranty or ...it will avoid exhaust parts...does anyone have afterm exhaust and still under warranty...&gt;?
what kind I should get...
I'm thinking about apex N1.
Hybrid ctr's Avatar
Default Re: warranty<<<>>>exhaust (gmsu00)
I'm sure exhaust won't cause any problems
Old Nov 27, 2001 | 11:10 PM
ZJ Nizzle's Avatar
New User
How much longer you do have on your warantee?
An exhaust will most likely kill it. Especially if you do the full cat back.
You have an intake? Those don't void anything, unless you hydro lock.
Hmm.. other things to consider... depends which dealer you go to. some of them are dicks.. others are really good and work on cars modded like crazy.
My friend has a Accord with a H22 swap... he pulled in to a stealership a couple weeks ago. They opened up the hood and were like.. yo... what did you do to the engine?
Errr.. retards.
Old Nov 27, 2001 | 11:12 PM
JSpecwest's Avatar
New User
Default Re: warranty<<<>>>exhaust (Hybrid ctr)
Unless you have some major mods, I wouldnt put an aftermarkert exhaust on If its your daily driver you probably will get annoyed by the N1 (its really loud) and you might run into warranty issues. Ive learned just to enjoy the car for what it is. Just my .02
Old Nov 27, 2001 | 11:15 PM
Lt. Dan's Avatar
Default Re: warranty<<<>>>exhaust (ZJ Nizzle)
Exhaust systems don't void anything except the warranty on your exhaust system... The only other thing I have ever NOT coverd under warranty because of an exhaust system was an 02 sensor, and that was because the guy had chewed it all up putting stuff on..... Honestly, a dealer is more likely going to be a bigger dick about the intake...
Dan
Old Nov 28, 2001 | 09:46 PM
gmsu00's Avatar
New User
Default Re: warranty<<<>>>exhaust (Lt. Dan)
so is it for sure that they won't avoid whole warranty and juss avoid exhaust parts and o2 sensor.
is this true. and N1 is too loud...&gt;?!
I'm a daily driver, I want the exhaust cuz of I'm getting JDM header and more hp than stock exhaust...
what do you guys think
Old Nov 28, 2001 | 09:51 PM
nfn15037's Avatar
Nothing you do to your car can completely void your warranty. Say you do full suspension, well, thats not covered anymore, but everything else is. Unless your dealer can prove that the modification caused the problem, they have to honor the warranty. Like they cant say your shocks and springs caused your computer to screw up, or something like that. Lame example, but you get my point.
Old Nov 28, 2001 | 09:55 PM
gmsu00's Avatar
New User
Default Re: warranty<<<>>>exhaust (nfn15037)
thanks nfn15037 . you juss cleared whole thing.
now ...what kind of exhaust I should get ...I want more hp.
Old Nov 28, 2001 | 10:02 PM
B2FiNiTY's Avatar
https://honda-tech.com/zerothread?id=88425
https://honda-tech.com/zerothread?id=86401
https://honda-tech.com/zerothread?id=84349
https://honda-tech.com/zerothread?id=85338
https://honda-tech.com/zerothread?id=90939
Check those out. A lot of reading but well worth it.
xnvb
15
Jan 23, 2009 05:47 AM
Turbo95LX-f20b
Mar 5, 2008 05:18 PM
2008fijibluesi
Honda Civic (2006 - 2015)
Nov 16, 2007 03:42 PM
