clutch problem....
Old Nov 27, 2001 | 09:11 PM
94acurals's Avatar
Default clutch problem....
hey whats up guys? well here is my problem. I get in my car today and my clutch doesnt feel right. usually it catches pretty high requires descent pressure to press down. so i get in and there is no pressure until about 2/3 the way down. it catches about a half inch off the floor now.... something isnt right. does anybody know what the problem is? btw, there is no grinding or gears or anything happening... it just feels real weird. oh yea, (it may just be in my head), but i might be hearing a slight jingle, something metallic, from the front right of the car, right where the clutch is.. can somebody help me out...... i appreciate it.. Thanks in advance
Old Nov 27, 2001 | 10:07 PM
FrostyGSR's Avatar
New User
Default Re: clutch problem.... (94acurals)
Dude, sounds to me like your clutch slave cyl. is leaking, check down by your clutch pedal to see if you are leaking fluid, when your fluid gets low, it will start to feel different, just the same as you are describing, I only know cuz it's happened to me.
Old Nov 28, 2001 | 07:47 AM
allenp's Avatar
I agree -- sounds like a leak in your clutch release system.
Whenever you lose fluid from the system, the effect is similar to air in your brake lines -- mushy pedal and no brakes! Air is very compressable and does not actuate the clutch like the fluid does -- so where the fluid has leaked out, air has replaced it, and hence your pedal feels soft and there's much less clutch travel.
Get this checked ASAP -- you may lose your release entirely, then good luck shifting.
Old Nov 28, 2001 | 01:12 PM
Mr. Softee's Avatar
Default Re: clutch problem.... (allenp)
i have hte same problem, i think its my pressure plate.
Old Nov 28, 2001 | 02:17 PM
94acurals's Avatar
Default Re: clutch problem.... (97lstegra)
damn this sucks... i checked under my clutch pedal today and sure enough, it was a little wet underneath. anybody know how much this is gonna run me up at the mechanic.. thanks...
Old Nov 28, 2001 | 05:29 PM
gsr camel's Avatar
I would bleed your clutch sys. then if it still happens then replace slave and if it still happens then replace your master and if it still is doing it then it could be real serious about a $400. problem cant member what it was called (I am quoteing a local mechanic that told me this when my slave cyl went bad)
Old Nov 28, 2001 | 08:10 PM
94acurals's Avatar
Default Re: clutch problem.... (gsr camel)
thanks for your help guys..
Old Nov 29, 2001 | 07:56 AM
allenp's Avatar
Quote:
"i have hte same problem, i think its my pressure plate."
What makes you think this?
I would check (for leaks, then bleed) your release system first before anything else. Only then, if that does not help, should you suspect the clutch itself. With these symptoms, it is far more likely to be the hydraulics.
Plus, it's a lot cheaper and easier to fix the release system than the clutch!
[Modified by allenp, 4:57 PM 11/29/2001]
Old Nov 29, 2001 | 01:34 PM
94acurals's Avatar
ok .. im gonna check for leaks... problem is.. how and where should i check. i know this sounds like a newbie question.. but i honestly know nothing about clutch/transmission stuff. ive done exhaust/intake/header, shocks, springs, brakes... but i never had to do anything with the clutch before. sorry for the dumb question.. but maybe someone can help me out .. thanks alot guys...
Old Nov 29, 2001 | 05:14 PM
Mr. Softee's Avatar
i pulled my tranny today, im gonna check it out tomorow. I DOUBT it was the hydraulic system to whomever said that... becuase i heard a loud *** ******* noise right before mine went bad.
CraiGlOl
Jul 9, 2009 07:52 AM
veilsides2000
Honda S2000
26
Dec 11, 2008 03:21 PM
B18Redline
Nov 13, 2007 11:09 AM
92hondalude
Jan 17, 2007 11:04 AM
armharm
Dec 14, 2002 11:29 PM
