Tranny Shifting problems...plz help
Old Jul 31, 2004 | 09:01 AM
Bigjussin's Avatar
Default Tranny Shifting problems...plz help
The jdm h22 tranny in my car has issues shifting into the top odd gears (1,3,5). It will pop out of 5th, should i check the fluid first or the linkage? has anyone else had this problem? the tranny has no more than like 35k miles on it, so im a little concerned, but im going to check and replace the MTF, make sure the clutch has enough fluid, and inspect the linkage to see what the deal is...is there any way a shift **** can affect performance? the tranny had a skunk2 **** on it, and the problem didnt seem to start until i put a stock gsr banana shifter on it....
TIA
Old Jul 31, 2004 | 09:37 AM
matix's Avatar
maybe try syncromesh mtf. It does wonders on are trannys.
Old Jul 31, 2004 | 11:02 AM
4bidden's Avatar
Default Re: (Turbo Sam)
Your cable is either not secured or it is cracked. Check the metal clips on the front side of the base plate and the ones right up by the transmission. If those are all there then your shift cable is busted. I'm guessing it is the cable since you mentioned you just messed wit hthe transmission.
Old Jul 31, 2004 | 05:17 PM
Bigjussin's Avatar
Default Re: (4bidden)
cool, thanks mucho dude...i was hopiing my tranny wasnt toasted...im gonn check those first thing when i get some light....
Old Jul 31, 2004 | 06:41 PM
vteckilla7's Avatar
Default Re: Tranny Shifting problems...plz help (Bigjussin)
I had the same problem in a gsr I had, the tranny only had like 40,000 on it too , and it would pop out of 5th, and the sychros were out
Old Aug 2, 2004 | 06:04 PM
Bigjussin's Avatar
Default Re: (Bigjussin)
took out the dc "short" shifter, and it seems to work a lot better and i lubed up the cables, so its smoother but still not perfect.....didnt have time to call honda to get a price on a new selector cable..so we'll see what happens
thanks to everyone for all your help
Old Aug 2, 2004 | 10:24 PM
Chris1091's Avatar
Use synchromesh. No doubtedly couldn't hurt.
jvo8
Aug 11, 2024 07:12 AM
ej1 pilot
Apr 9, 2006 02:50 PM
deagleEF8
Apr 26, 2004 08:19 PM
shadowstylz
May 20, 2003 04:10 AM
professorman
Feb 14, 2003 08:10 AM
