GSR Calipers
Old Jul 31, 2004 | 06:32 AM
SpydiR's Avatar
Default GSR Calipers
I've already done a search and found what was required to mount GSR calipers on my non-abs eg cx. What I want to know now is if it's worth it or not. What other braking upgrades should I be looking at instead? Post some opinions, I'm thinking of picking up some Monday.
Old Jul 31, 2004 | 07:01 AM
pdiggitydogg's Avatar
its quite a bit of a braking difference over the small hatch brakes, apparently.
Another option is a larger booster/mc combo to stiffen up the pedal feel.
Old Jul 31, 2004 | 08:24 AM
elwood's Avatar
Default Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">
Another option is a larger booster/mc combo to stiffen up the pedal feel.</TD></TR></TABLE>
But your braking will still be ****.
I would try to find the whole knuckle, it will save you a lot of trouble,
but if you think you can do it and want to save the money, oem bigger
brakes cant hurt.
Old Jul 31, 2004 | 08:33 AM
egizzle8
Guest
Posts: n/a
Default Re: (elwood)
You could always just get new rotors and a nice set of pads and some SS brakelines and a fancy brake pedal cover!
Old Jul 31, 2004 | 12:07 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elwood &raquo;</TD></TR><TR><TD CLASS="quote">
I meant it as an option after the caliper swap
Old Jul 31, 2004 | 09:27 PM
SpydiR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">Another option is a larger booster/mc combo to stiffen up the pedal feel.</TD></TR></TABLE>
This is going to be done anyway, hoping to pick up either teg or Si trailing arms while I'm at the junkyard.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elwood &raquo;</TD></TR><TR><TD CLASS="quote">I would try to find the whole knuckle, it will save you a lot of trouble,
brakes cant hurt. </TD></TR></TABLE>
Yea, I'm trying to score a set of knuckles. I heard you can use VW Corrado rotors with the teg caliper set up. They're supposed to be something like 11", anyone do this?
Old Jul 31, 2004 | 09:35 PM
spock_rocker's Avatar
memoryFAB.com representative
Default Re: (SpydiR)
i found a wrecked EX at a junkyard. i think im gonna take the front knuckle off that and use those to replace my tiny brakes!!
Old Jul 31, 2004 | 09:37 PM
ABK's Avatar
ABK
Default Re: (spock_rocker)
yeah when you upgrade your cx brakes to 10.2" unit the car brakes like it's crazy. Car just stops, no brake fade nothing. Amazing improvment.
Old Jul 31, 2004 | 11:42 PM
elwood's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpydiR &raquo;</TD></TR><TR><TD CLASS="quote">I heard you can use VW Corrado rotors with the teg caliper set up. They're supposed to be something like 11", anyone do this?
You minght be thinking of the prelude vtec callipers.
I have heard you can use the veedub stuff but my
rotors were just re drilled to 4x100.
Old Aug 6, 2004 | 07:51 AM
jpb105079's Avatar
Default Re: GSR Calipers (SpydiR)
why would u want to put gsr calipers on ur civic? are u planning on getting gsr rotors also cause it would probably be easier to get the whole steering spindle from a salvage yard.
Old Aug 6, 2004 | 08:09 AM
integra calipers are larger than civic ones...all of them. The ex/si have the same size rotor as integras
(i never understood why people say "gsr calipers" since theyre all identical -ls/gs/gsr)
poormans_typer69
Jan 11, 2008 03:24 PM
slvrlude
Apr 8, 2007 12:56 PM
freakasis
21
Jun 10, 2006 01:50 PM
spoonef
Northwest (Sales)
11
Oct 16, 2005 02:33 PM
Infamous_Imports
Oct 7, 2004 01:45 PM
