best sway bar set up for the street
Old Jul 31, 2004 | 12:49 AM
slow motion's Avatar
Default best sway bar set up for the street
Modified by slow motion at 7:51 PM 10/3/2004
Old Jul 31, 2004 | 02:21 AM
jc836's Avatar
Default Re: best sway bar set up for the street (jdm's finest)
Although SEARCH is your friend-might I suggest that you look at ADDCO or ST for a set of streetable/autocross bars. Our '96 HB had ST's front and rear and the car was very responsive. Then again I did have stiffer springs and Konis all around. It really depends on your plan for the car. BTW: personal preference is ADDCO (available direct or from Summit)
Old Jul 31, 2004 | 04:17 AM
heel_touge's Avatar
Default Re: best sway bar set up for the street (jc836)
comptech for the rear.
keep that subframe inforced.
Old Jul 31, 2004 | 04:32 AM
JDMlyfestyle's Avatar
Im looking into the SRR kit. looks very nice.
Old Jul 31, 2004 | 12:14 PM
Default Re: (JDMlyfestyle)
both comptech and srr only make the rear. looking for an all around set up (front & rear) or what would you use in the front with the comptech or srr in the rear?
Old Jul 31, 2004 | 12:23 PM
piscorpio's Avatar
Suspension Techniques rear bar worked great for me (00 EX coupe, as well as 92 VX hatch). No reinforcement used, looked fine after 2.5 years of use on my coupe. I used the bar with APEXi WS coilovers also.
Old Jul 31, 2004 | 12:27 PM
powerfulperformance's Avatar
Default Re: best sway bar set up for the street (piscorpio)
stock civic si for the front and computech for the rear, in an ek...
Old Jul 31, 2004 | 02:11 PM
deviant1's Avatar
Default Re: best sway bar set up for the street (powerfulperformance)
if you cant afford comptech, then go with 99-00 Si front sway with Si LCAs and forks, and a ITR rear with beaks kit. good idea to upgrade to stiffer springs while you are at it.
Old Jul 31, 2004 | 10:07 PM
Default Re: best sway bar set up for the street (deviant1)
thanks. anymore recommendations?
Old Jul 31, 2004 | 10:18 PM
turbotime's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm’s finest &raquo;</TD></TR><TR><TD CLASS="quote">thanks. anymore recommendations?</TD></TR></TABLE>
I just bought the eibach anit-roll kit for the 92-95, its 22mm in front and 19mm in back, i should have it in like 3 days. Just bought it on ebay $150.00 brand new....(some guy bought the wrong kit cause he didnt have a stock front swaybar, which you need for the kit)
I'll post how it goes ASAP
Old Jul 31, 2004 | 10:25 PM
buckNasty's Avatar
Default Re: best sway bar set up for the street (turbotime)
i got the comptech rear kit
stock front
tein ss
after i get new tires and an alignment
ill be loving it lol
but im looking at a ST front sway setup to upgrade the stocker
Old Jul 31, 2004 | 10:44 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotime &raquo;</TD></TR><TR><TD CLASS="quote">
I'll post how it goes ASAP</TD></TR></TABLE>
yeah i saw that on ebay. nice price. too bad mine's a 99, i would've outbid you
Old Jul 31, 2004 | 10:47 PM
JDM R's Avatar
99-00 Civic Si swaybars in a hatch is perfect for the streets
Old Aug 1, 2004 | 10:35 AM
ttt
Old Aug 1, 2004 | 11:05 PM
so i guess that's about it...
Old Aug 1, 2004 | 11:11 PM
rMak's Avatar
depends on how you drive. if you wanna dial out understeer, just keep the front and beef up the rear. i have an si sway on the back, and i kinda want more. its 13mm. integra rear sways are 14. ctr rear is 17, or itr i dont remember. comptechs and ss those go around 22mm. hope the numbers help you.
Old Aug 2, 2004 | 04:38 PM
piscorpio's Avatar
Default Re: best sway bar set up for the street (slowEJ8)
I believe the ST rear is about 19mm.
Mooneyes13
Suspension & Brakes
Mar 2, 2005 11:45 AM
lowrightor
Jul 23, 2004 09:02 AM
94ls
Mar 26, 2003 11:58 AM
tinkfist
Aug 23, 2002 06:52 AM
kefka
Mar 31, 2002 08:10 AM
