Limp Mode??!?
Old Jul 30, 2004 | 07:44 PM
mugenhatch92's Avatar
Default Limp Mode??!?
ok well...... my car is limp....... yes its sad, i tried viagra levitra, but all gave erections for over 4 hours so i had to stop......... but anyway...
i have these codes...
Intake Air Temp <-- not plugged up
Secondary O2 <-- not plugged up
Vtech Pressure Switch <-- working on plugging up
Map Sensor <--- dont know why.....
which of these is putting me into limp mode? or is it just more than 2 codes with throw you into limp stage or what?
<--- trying to learn
Old Jul 30, 2004 | 10:09 PM
alleyezonme's Avatar
Default Re: Limp Mode??!? (mugenhatch92)
probably your O2 sensor...
Old Jul 30, 2004 | 10:14 PM
Kal's Avatar
Kal
Default Re: Limp Mode??!? (bumpincivic20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bumpincivic20 &raquo;</TD></TR><TR><TD CLASS="quote">probably your O2 sensor...</TD></TR></TABLE>
Old Jul 31, 2004 | 09:04 AM
wrong it revs to 5200 which is basically what it does with no vtec....... limp mode would be 4200 and running without a secondary o2 sensor wont do anything
Old Jul 31, 2004 | 11:21 AM
wait, so you aren't in limp mode? if you can rev up to 5200 and nothing else, then i would say it is your vtec pressure switch, hook that back up. and be a little more clear, i thought you were in limp mode.
Old Jul 31, 2004 | 05:23 PM
vtec69's Avatar
my car went into limp mode when my vtec ground wire came off if that helps at all
sireg6
Jun 2, 2007 02:55 AM
eswaroop
Apr 14, 2004 11:17 AM
Frankinfreak300
Sep 26, 2003 09:46 AM
ramz7887
Aug 19, 2003 01:18 PM
