battery relocation???
hey whats up ppl...i was wondering how does one relocate the battery to the back in a 94 civic EX..ok the battery is set up that the power side is running to the fuse box and another cable to the starter...then of course the negative cable is grounded.
how do u run the cables to the back? what goes connected to what??? where do u connect the starter too, the fuse box goes to what and then the alternator goes connected where...
It's like running an amp to the back. Take the power to the trunk and make sure you fuse that baby under the hood yourself. Then you can pick any ground from the trunk. Just make sure you use the right gauge wires (4 gauge I believe). But why would you do that on a fwd? You want the least weight in the rear and most in front while having the weight of the car as least as possible.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by murtnabila »</TD></TR><TR><TD CLASS="quote">It's like running an amp to the back. Take the power to the trunk and make sure you fuse that baby under the hood yourself. Then you can pick any ground from the trunk. Just make sure you use the right gauge wires (4 gauge I believe). But why would you do that on a fwd? You want the least weight in the rear and most in front while having the weight of the car as least as possible.</TD></TR></TABLE>
Maybe for a clean engine bay. Nothing wrong with that
lilo_goki
Aug 22, 2008 03:46 PM
FUP23
Aug 6, 2002 01:14 AM
