Distributer problems!!!
Old Jul 30, 2004 | 03:02 PM
Eresuncabron's Avatar
Default Distributer problems!!!
Well I've been having problems with my LS swap and I was going over everything today...
I pulled off my cap and my rotor was actually hitting contacts on the distributer cap!
Should I just go for a whole new distributer or is there a way to fix the rotor...
If I jiggle it back and forth there is almost 1/4 of an inch of play. Why? and what to do?
Old Jul 30, 2004 | 03:16 PM
Jester88Si's Avatar
Default Re: Distributer problems!!! (Eresuncabron)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eresuncabron &raquo;</TD></TR><TR><TD CLASS="quote">Well I've been having problems with my LS swap and I was going over everything today...
If I jiggle it back and forth there is almost 1/4 of an inch of play. Why? and what to do?</TD></TR></TABLE> Is it an oem rotor? is the whole dizzy moving or just the rotor? if its just the rotor try a different brand or OEM (Best ). Hey hows the hesitation between idle 3k have you fixed it? I got mine fixed I'm not sure if it'll help you since yours is already a si but pm if you wanna know what I did...
Old Jul 31, 2004 | 11:44 PM
Default Re: Distributer problems!!! (Jester88Si)
yeah... it's just the rotor thats movin... so i'm gonna get a whole new one i think....
i took my car to the track last wednesday... i ran a 16.7 like 3 times in a row...
i ran a 15.9 with my stock si... and i'm pissed.
my bro says i can't drive... thats why it's slower... but i ran my stock si months ago and i havn't gotten worse at drivin I don't think
my bro says i can replace the rotor...? is that hard?
Old Aug 1, 2004 | 02:25 PM
Jester88Si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eresuncabron &raquo;</TD></TR><TR><TD CLASS="quote">yeah... it's just the rotor thats movin... so i'm gonna get a whole new one i think....
my bro says i can replace the rotor...? is that hard?</TD></TR></TABLE>
Yes just replace the rotor its not hard remove the small plastic cover if its original it'll be held on there with hex bolt if its not oe it'll probably phillips head. As for the slowness I think you have the same Problem I had My hesitation was bad and it was also causing me to feel like I had little power, but once I fixed it man it hauled . Are you getting any CELs?
Old Aug 1, 2004 | 09:37 PM
No cel's
Old Aug 1, 2004 | 10:55 PM
crxtim's Avatar
it sounds like the bearing inside the distributer is bad. if you have and extra distributer with a bad sensor you could swap shafts. or just buy another distributer but try a rotor it is the cheapest solution.
Old Aug 2, 2004 | 09:07 AM
Default Re: Distributer problems!!! (crxtim)
Ok thanx
Old Aug 2, 2004 | 09:59 AM
Jester88Si's Avatar
You should be able to tell if its the shaft or rotor.... Hows the hesitation, did you try what I told you?
Old Aug 2, 2004 | 03:24 PM
Well it ended up being the rotor...
The metal piece inside the plastic rotor piece was loose. EZ fix.
but now I need a new cap... pepboys didn't have any, I sure wish there were an autozone around.
Old Aug 2, 2004 | 03:26 PM
Jester... i've written to you online two times on AIM
my sn is SteveVindler....so write back sometime
Old Aug 2, 2004 | 05:46 PM
Jester88Si's Avatar
Sorry been busy....lol I'll get on aim right now
Old Aug 3, 2004 | 01:32 PM
Default Re: (Jester88Si)
OK cool thanx
Tec Nine
Jun 1, 2005 11:38 AM
PowderB16
10
Nov 15, 2004 06:46 AM
JMD
Sep 29, 2004 09:46 PM
jaycapz
Sep 12, 2004 06:03 AM
-faded-
Jul 19, 2004 02:54 PM
