my 99 si's idle?
Old Jul 30, 2004 | 02:16 PM
gobblebox59's Avatar
Default my 99 si's idle?
hey guys my 99 civic si has a wierd idle problem right now, lately the idle just jumps between 1grand and a half when i leave it running and just sit there for a lil bit, the car starts to shake when the idle gets low and it doesnt go back up to normal unless i give it some gas. my idle adjustment is fine so idk what could be causing this? need new spark plugs or something dumb? heh
Old Jul 30, 2004 | 02:18 PM
TurboEH2's Avatar
Default Re: my 99 si's idle? (gobblebox59)
could be alot of things, not getting enough spark, the IAVC needs to be cleaned is it throwing any CEL's?
Old Jul 30, 2004 | 02:40 PM
SiRGodfather's Avatar
What are your mods if any?
Old Jul 30, 2004 | 02:47 PM
Default Re: my 99 si's idle? (SiRGodfather)
dc 4-1 sport headers, aem cold air intake, apexi world sport exhaust, alot of minor things like msd spark plug wires and what not, my car just seems to be running really rough and the idle doesnt stay at right below a grand where it used to, it just dips down to like 400-500 alot and seems like my cars gonna die but it hasn't yet. idk thanks for advise guys.
Old Jul 30, 2004 | 02:48 PM
btw 113,000 miles have anything to do with it? everything else seems to run fine though!
Old Jul 30, 2004 | 03:02 PM
jerbear!'s Avatar
whats with all these weird idle questions. its normal to have idles below 1k. the way i figure is that its summer and its hot.. that must have to play a big role
Old Jul 30, 2004 | 03:16 PM
Default Re: (jerbear!)
good reasoning!
Old Jul 31, 2004 | 12:03 PM
TurboEH2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jerbear! &raquo;</TD></TR><TR><TD CLASS="quote">whats with all these weird idle questions. its normal to have idles below 1k. the way i figure is that its summer and its hot.. that must have to play a big role</TD></TR></TABLE>
yeah i have been noticing alot also.
Old Jul 31, 2004 | 01:06 PM
slow99si's Avatar
Default Re: (VTECschmetec)
mine idled funny and my intake came loose and i just needed to tighten it down to the throttle body better ... i dunno ... thats what i did
Old Jul 31, 2004 | 08:51 PM
B9000rpm's Avatar
It's pretty normal. my si does it, and i have about the same setup. I wouldn't worry about it unless you have an engine code goin off.
Old Jul 31, 2004 | 08:52 PM
slow fkn hatch's Avatar
Default Re: my 99 si's idle? (B9000rpm)
my old car, a 98 ex with ls motor.. did that a few times. then i noticed the vaccum hose was disconnected.. i mean, it's kind of noticeable if you know wtf it is, but obviously i didnt until i saw a little hose just dangling.
Old Jul 31, 2004 | 08:54 PM
Jimmy's Avatar
Global Moderator
Possible ignitor failing
Old Aug 2, 2004 | 12:57 PM
93civicdead's Avatar
Default Re: (Jimmy)
my car has been doing it too but mine will idel at 1 then when im driving it will stay at 2 and sometimes if i give it gas it will go back down to one then right up to 1500 and sometimes it stays at 3..... does anyone know what i shoudl do
Old Aug 2, 2004 | 01:51 PM
kommon_sense's Avatar
Default Re: (93civicdead)
ever replaced your ground wires? Particularly the one from the valvecover to the chassis? I've got about 115k on my 98ex and was having low idle issues. Car would almost cut-off, but not quite. Give it gas and it was fine. Replaced my ground wires and problem is gone. Real easy to make your own with some 8 guage wire and gold plated terminals.
DaX
Oct 24, 2018 04:56 AM
hell0curry
Apr 4, 2012 11:20 PM
abusedvtec
Sep 1, 2009 01:44 PM
twisted civic
Jul 19, 2008 11:09 AM
