***SRP Pistons
i want to go turbo and am in the process of building up my engine first. first of all i just want to run 10-14 PSI. would SRP pistons CR 8:5.1 be sufficient enough for that power? i have a f22a1 vtec engine with 145 hp stock
building a f22b2 here just run an eagle h22 rod and a custom piston which is the expensive part about 450bux a set and the rods are 339 a set just run like je rings or something else, something that would work with a 85mm bore hope it turns out good
bigbpatel
Nov 8, 2012 01:56 PM
