***SRP Pistons
Old Nov 27, 2001 | 05:51 PM
accordfreak's Avatar
Default ***SRP Pistons
i want to go turbo and am in the process of building up my engine first. first of all i just want to run 10-14 PSI. would SRP pistons CR 8:5.1 be sufficient enough for that power? i have a f22a1 vtec engine with 145 hp stock
Old Nov 27, 2001 | 06:08 PM
importboi22's Avatar
Default Re: ***SRP Pistons (accordfreak)
building a f22b2 here just run an eagle h22 rod and a custom piston which is the expensive part about 450bux a set and the rods are 339 a set just run like je rings or something else, something that would work with a 85mm bore hope it turns out good
bigbpatel
Nov 8, 2012 01:56 PM
LS/V-T
Jan 5, 2011 09:19 AM
Bonestock98GS
Oct 1, 2009 05:10 PM
buffgsr
Sep 18, 2007 05:02 PM
Harddrnker
Feb 16, 2004 09:11 AM
