b18 type r motor, with a 1.6 sohc ecu, throwing code 21 (vtec spool)
Old Jul 30, 2004 | 09:17 AM
Tracy's Avatar
Default b18 type r motor, with a 1.6 sohc ecu, throwing code 21 (vtec spool)
Hey,
i am having trouble with a integra that is at the shop. it has a turbo b18 motor with a sohc 1.6 vtec ecu, a p28 i think. the thing wont go into vtec, it is throwing a code 21, which is vtec spool error. i am using a hondata s200 with the car. i have tried swapping the vtec pressure switch and the vtec solenoid. what is the root of the code 21, is it the solenoid or is it caused from another problem, like knock or vss???
tracy
Old Jul 30, 2004 | 09:22 AM
dsadas89das78934's Avatar
no... you need to make sure that the positive lead coming from the vtec solenoid is connected to the ECU.
is the car using a conversion harness? or is it already an OBD1 car?
Old Jul 30, 2004 | 01:11 PM
JinDIESEL's Avatar
Default Re: (soccaian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soccaian &raquo;</TD></TR><TR><TD CLASS="quote">no... you need to make sure that the positive lead coming from the vtec solenoid is connected to the ECU.
is the car using a conversion harness? or is it already an OBD1 car?</TD></TR></TABLE>
i hope this problem doesnt occur when i put the jdm itr engine in my car..
Old Jul 30, 2004 | 02:10 PM
bpowa's Avatar
Default Re: (JinDIESEL)
had the same problen.. vtec clicked to 12v.. but it was the wiring.. a4 and d6 pins were switched .. i just switched it back and problem solved.
obuhmyuh
20
Apr 21, 2008 02:35 PM
slowr6
Mar 27, 2007 04:51 PM
wfo
Feb 25, 2005 02:21 PM
EF4lyfe
Sep 7, 2004 04:52 PM
