4 wheel disc breakes ???? on a crx
Old Jul 30, 2004 | 07:53 AM
crxzcracer's Avatar
From: Murfreesboro, Tennessee, United States of America
Default 4 wheel disc breakes ???? on a crx
i am going to do a 4 wheel disc on my 91 hf crx i have a 90 si crx that i am getting parts off of i was just whating to know if there are any post aboult this i could not find any when i searched
also how do i get the si master brake cylinder out?
Old Jul 30, 2004 | 07:59 AM
virginia_dude's Avatar
Default Re: 4 wheel disc breakes ???? on a crx (crxzcracer)
Take a look at the Master cylinder. see the 4 nuts? take those off and the lines and the M/C is in your hands. The booster is a bit harder but if yours works why bother.
You want the front suspension, the rear suspension, E-brake cables and Rubber brake lines, And you want the porportioning valve..
Old Jul 30, 2004 | 08:03 AM
crx_88_si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxzcracer &raquo;</TD></TR><TR><TD CLASS="quote">
also how do i get the si master brake cylinder out?</TD></TR></TABLE>
it's basically a remove hf parts replace w/ si parts.
use the si ebrake cables and brake lines.
the master cyl is easy, 2 brake lines, 2 bolts (or nuts?) and its off.
becareful of the brake fluid. it eats paint. wear rubber gloves.
Old Jul 30, 2004 | 08:14 AM
crxzcracer's Avatar
Default Re: 4 wheel disc breakes ???? on a crx (crx_88_si)
okay sorry i am talking aboult the black thing behind the master cly. but is there any point to changing them? or is the si more powerful
Old Jul 30, 2004 | 08:21 AM
EL Vap133's Avatar
I would only change the booster if you were getting big brakes like Teg or 90-91 EX Civic brakes.
Old Jul 30, 2004 | 08:29 AM
crxzcracer's Avatar
Default Re: 4 wheel disc breakes ???? on a crx (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si &raquo;</TD></TR><TR><TD CLASS="quote">
why do i have to use the si ebrake cables how are they diffent from what is already on the hf And same for the brake lines i already have brake lines running back there so why do i have to replace them?
sorry i am stupid so i ask a alot of ?'s
Old Jul 30, 2004 | 08:33 AM
EL Vap133's Avatar
Because you currently have e-brake cables that were meant for use for rear drums, you are going with rear disc brakes so you need e-brake cables for rear discs, the bracket where it mounts on the brakes is different.
Old Jul 30, 2004 | 08:38 AM
crx_88_si's Avatar
yes. You dont need to replace the brake fluid hard lines, just the rubber ones.
Old Jul 30, 2004 | 10:40 AM
crxzcracer's Avatar
okay yeah i see aboult how long would this swap take?
and how hard is it to disconnet the ebrake and run the new lines
Old Jul 30, 2004 | 10:53 AM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxzcracer &raquo;</TD></TR><TR><TD CLASS="quote">okay yeah i see aboult how long would this swap take?
and how hard is it to disconnet the ebrake and run the new lines</TD></TR></TABLE>
It's only hard to get the tool you need in between the gas tank and the opening where the bolts are at, if you can do that then it's not hard at all.
The DX Rex
13
Nov 4, 2013 05:06 AM
delinquent
Sep 12, 2009 04:18 AM
ZenBearClaw
Jun 20, 2006 05:19 AM
luciffer
Aug 25, 2005 01:15 PM
