How to cut fuel?
on hondas you have to disconnect the connector to the fuel pump, lift up the rear seat and you should see a cover with about three screws, remove that cover and there should be two connectors, one for the sending unit and one for the fuel pump, disconnect the two and you will cut off the fuel
m.glisson003
Oct 31, 2011 05:53 PM
