cold air intake
Old Jul 29, 2004 | 10:39 PM
dcrbin22's Avatar
Default cold air intake
i have a cheap short ram right now , i can tell a diffrence in performance in hot weather the car sucks bad in it. I was wondering if i could add a piece to it , so its a cai , but does someone have pics of where it would go the hole for the stock pipe is pretty small.
Old Jul 30, 2004 | 08:37 AM
fireslinge's Avatar
Default Re: cold air intake (dcrbin22)
almost all cai's cut that hole to fit the pipe so you will proably have to also.
Old Jul 30, 2004 | 08:41 AM
98TypeSH's Avatar
Default Re: cold air intake (fireslinge)
yea i had to cut mine to get that bish to fit. just stuck a dremel cutting disk on there and grind away.
Old Jul 30, 2004 | 11:31 AM
ralpheezy's Avatar
This is what mine looks like. They had to cut a bigger hole for the pipe to go all the way down.
I have a question also.
Am I able to remove the bottom edn of my pipe below the bypass valve and put the filter on there to make it a short ram intake for when it is raining too hard or there is too much moisture. Thanks for help.
Old Jul 30, 2004 | 03:39 PM
eLUDEnu
Guest
Posts: n/a
Yeah aslong as your filter fits
Old Jul 30, 2004 | 07:31 PM
Kal's Avatar
Kal
stupid small hole...but yeah, you can make it a SRI if weather gets too bad as long as you can find a filter that fits the pipe at its angle and proximity to the other areas of the car.
Old Jul 30, 2004 | 08:31 PM
ralpheezy's Avatar
Default Re: cold air intake (Kal)
How would you make it fit? Won't the pipe bounce up and down or something since it won't be attached where the hole is no more? What tools would I need to do this?
Old Jul 30, 2004 | 08:37 PM
dawalude's Avatar
Default Re: cold air intake (ralpheyizzle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ralpheyizzle &raquo;</TD></TR><TR><TD CLASS="quote">How would you make it fit? Won't the pipe bounce up and down or something since it won't be attached where the hole is no more? What tools would I need to do this?</TD></TR></TABLE>
it wouldnt be bouncing up and down because 1) you should have tightened the pipe on the throttlebody side tightly with the round bracket, and 2) since you have AEM, there should be a mounting bracket that holds the pipe in place
Old Jul 30, 2004 | 08:44 PM
ralpheezy's Avatar
Default Re: cold air intake (dawalude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dawalude &raquo;</TD></TR><TR><TD CLASS="quote">
it wouldnt be bouncing up and down because 1) you should have tightened the pipe on the throttlebody side tightly with the round bracket, and 2) since you have AEM, there should be a mounting bracket that holds the pipe in place</TD></TR></TABLE>
If I make it a short ram while its raining too much I would have to take off the mounting bracket. Would that be a problem? I tightened the pipe on the throttle body but thats all it would be attached to.
Old Jul 30, 2004 | 08:53 PM
dawalude's Avatar
shouldnt be a problem at all. there will be slight movement from whenever you accelerate hard but nothing to worry about
and btw, why would you have to remove the bracket to make it a short ram?? is your bracket mounting on the 2nd pipe after your bypass valve?
Old Jul 30, 2004 | 11:54 PM
dcrbin22's Avatar
Yeah that shorter half of yours looks like mine what pipe should i get to make the other half
Old Jul 30, 2004 | 11:55 PM
dawalude's Avatar
any pipe that fits...you can buy a civic one off ebay or whatever is cheapest. or, get the same diameter pvc pipe and route it that way..
Old Jul 30, 2004 | 11:56 PM
dcrbin22's Avatar
you could make it a short ram , my short looks exactly like yours minus the other half
Old Jul 31, 2004 | 12:15 AM
Saki's Avatar
Exactly and CAI can be converted to a Short Ram
Short Ram from my old lude...
CAI in my other lude... (Don't Mind the Ties lol )
Saki
Old Jul 31, 2004 | 12:30 AM
dawalude's Avatar
Default Re: cold air intake (Saki)
hahaha very nice ties...
Old Jul 31, 2004 | 05:40 AM
ralpheezy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dawalude &raquo;</TD></TR><TR><TD CLASS="quote">shouldnt be a problem at all. there will be slight movement from whenever you accelerate hard but nothing to worry about
and btw, why would you have to remove the bracket to make it a short ram?? is your bracket mounting on the 2nd pipe after your bypass valve? </TD></TR></TABLE>
Yeah the mounting bracket is on the 2nd pipe so I would have to take that off. Would that still be a problem?
Espincivic
Sep 20, 2016 02:13 PM
BloodRedS2k
Honda S2000
20
Mar 5, 2010 07:20 AM
joshuaaaronalpert
Sep 22, 2006 10:47 AM
shutta
Sep 23, 2005 11:39 AM
cbmprelude
Mar 23, 2004 11:34 AM
