might be the starter
Old Jul 29, 2004 | 10:33 PM
xoutlawz00x's Avatar
Default might be the starter
k it all started when i got the car (97 civic hacth) and when ever i get low on gas its seems to have a harder time to start the car?? y is that???.. i put fuel injector cleaner and it sill does it.. now the start i think is mess up cause with i full take i try to start it and it take a couple turns..
Old Jul 29, 2004 | 10:37 PM
hondachick05's Avatar
Default Re: might be the starter (xoutlawz00x)
get a new starter and see if that does the trick
Old Jul 30, 2004 | 08:02 AM
Default Re: might be the starter (hondachick05)
but do u think the bad starter had suttin to do with it taking a longer time to start when low on gas
Old Jul 30, 2004 | 08:27 AM
Deemeetree's Avatar
Electrician
How about not letting the fuel level go below 1/2 a 1/4 tank and call it a day?
Old Jul 30, 2004 | 12:03 PM
i dont know about that part but if it doesnt work anymore even with the tank full than its the starter. Just get a new one and see what it does. if its still harder to start when its 1/2 or 1/4 full then u might want to get it checked out and see what the problem is but deffinately try the new starter
Old Jul 30, 2004 | 12:05 PM
JinDIESEL's Avatar
simple solution - get gas refills more often
Old Jul 30, 2004 | 12:21 PM
slamedturtle's Avatar
okay i had this same problem in my 93 hatch. every time it would do it i would just go and unscrew the gas cap and start it. it would start just fine and then screw the cap back on. never could pin point what this was from or never thought to look into it any farther. i just figured it was because i lost the honda gas cap and had to replace it with a after market cap. so i figured it just started to cause fuel pressure problems after i would turn the car off. because believe it or not the gas cap does matter. and i never had the problem before i put that cap on. just try it and see if it works if so go and get the honda cap. anyways good luck.
Old Jul 30, 2004 | 12:24 PM
djsire's Avatar
Default Re: might be the starter (slamedturtle)
cough bullshit cough
Old Jul 30, 2004 | 01:57 PM
Default Re: might be the starter (djsire)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djsire &raquo;</TD></TR><TR><TD CLASS="quote">cough bullshit cough </TD></TR></TABLE>
whatever bitch. ohh yeah its like that here in texas.
Oh and sorry for whoring up your post here.
Old Jul 31, 2004 | 08:44 PM
Default Re: might be the starter (JinDIESEL)
umm yea i know i can do that u **** but i wanna find out the problem its not supposed to do that. im not gonna keep suttin on the car while it prolly gettin worn away. if u don't got an answer shut the **** up.
Old Jul 31, 2004 | 08:45 PM
ohh yea thanks for ur help ill try it out
Old Jul 31, 2004 | 08:59 PM
honda9369's Avatar
fuel filter?
Old Jul 31, 2004 | 09:40 PM
Jimmy's Avatar
Global Moderator
Please don't waste your own money..
never just throw parts at your car or as a matter of fact ANY car
twistless
Classic Hondas
Jun 19, 2011 11:23 AM
CHINPIN
Apr 7, 2005 10:39 PM
MugenAccordSedan
May 10, 2004 03:29 PM
gliaw
Nov 21, 2002 02:53 PM
goforbroke
Sep 21, 2002 07:14 AM
