problem my car stalled in middle of street...
Old Jul 29, 2004 | 08:25 PM
dungsta's Avatar
Default problem my car stalled in middle of street...
i have a problem with the car..
its the 2nd time this happend
while i was driving the car just stalled and shut off
my check light came on and my friend told me it was
the fuse ... i just got a sub and alarm installed
is there something touching? to cause the fuse to blow out?
Old Jul 29, 2004 | 10:49 PM
Dr. EKology's Avatar
Default Re: problem my car stalled in middle of street... (dungsta)
Hmm, tough to say. Have you tried pulling the CEL code?
Old Jul 29, 2004 | 11:39 PM
dungsta's Avatar
Default Re: problem my car stalled in middle of street... (EKology)
wats a CEL code
ahah
Old Jul 29, 2004 | 11:42 PM
Opie's Avatar
WTF happened to the English language?
Old Jul 30, 2004 | 12:42 AM
InsertRacialSlur's Avatar
* B A N N E D *
Default Re: (opie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by opie &raquo;</TD></TR><TR><TD CLASS="quote">WTF happened to the English language?</TD></TR></TABLE>
It died. .
Old Jul 30, 2004 | 02:01 AM
DCR's Avatar
DCR
Default Re: (TypeRWanter)
This also happened to me, car would just shut off while moving. Turns out that it was a bad distributor.
Old Jul 30, 2004 | 05:14 AM
nEoMuGen's Avatar
Default Re: (DCR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DCR &raquo;</TD></TR><TR><TD CLASS="quote">This also happened to me, car would just shut off while moving. Turns out that it was a bad distributor.</TD></TR></TABLE>
Mine too...especially running with AC for a while, the damn thing just idle low enough to shut itself off.
Old Jul 30, 2004 | 07:16 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dungsta &raquo;</TD></TR><TR><TD CLASS="quote">wats a CEL code
ahah</TD></TR></TABLE>
Check Engine Light. Do you know how to jump the system and pull the code?
Old Jul 30, 2004 | 07:18 AM
JDM CTR '00's Avatar
here is how to check the CEL
http://www.c-speedracing.com/faq/06.php
Old Jul 30, 2004 | 07:22 AM
Nishant's Avatar
Default Re: problem my car stalled in middle of street... (JDM CTR '00)
see what CEL it is, that should tell you your problem
Old Jul 30, 2004 | 03:40 PM
dungsta's Avatar
Default Re: problem my car stalled in middle of street... (swtxaznrac3r)
i've replaced the distributor just last week!
and the same problem happend ...
can there be something wrong with the fuse to cause the car to stall?
some guy told me my fuse blew out because how my alarm was set up..
please help
Old Jul 30, 2004 | 03:41 PM
dungsta's Avatar
up up
Old Jul 30, 2004 | 03:52 PM
Kamil's Avatar
Could be any number of things. Have you had a tune up recently?
TPS maybe?
Fauled plugs?
Incorrect gaps on plugs?
Dirty fuel cleaner?
See what the CEL is as others have said above.
Anything is possible w/ a badly hacked alarm system. Depending on an alarm, it may shut the engine off either thru the fuel pump or ignition. Anti-car-jeck feature type deal.
Wanna sell your car [cheaply] as-is?
Old Jul 30, 2004 | 04:00 PM
SynTeg's Avatar
Check all the fuses under the steering wheel because my car died out because my FUEL PUMP fuse blew.
Old Jul 30, 2004 | 08:48 PM
dungsta's Avatar
Default Re: (SynTeg)
how can u tell if a fuse has died out?
they all look the same haha
Old Jul 30, 2004 | 09:50 PM
cheezthis's Avatar
Default Re: (dungsta)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dungsta &raquo;</TD></TR><TR><TD CLASS="quote">how can u tell if a fuse has died out?
they all look the same haha </TD></TR></TABLE>
Whoa...maybe you should stay away from working on your car then.
A blown fuse will be broken on the inside or black usually.
mortificationrock
Jan 31, 2008 08:29 AM
Lithel
Jan 21, 2008 03:14 PM
Flava
Aug 3, 2006 04:36 PM
ondahush
May 19, 2006 02:42 AM
BI8B
10
Mar 27, 2006 10:48 AM
