all motor 220 230hp ,
Old Jul 29, 2004 | 03:19 PM
hondahb12's Avatar
Default all motor 220 230hp ,
what set up would would i need to reach this goal, i have both block b18c and b18b, which one should i go and get sleeve,,going with 85bore
Old Jul 29, 2004 | 04:23 PM
RAS Motorsports's Avatar
Default Re: all motor 220 230hp , (hondahb12)
take the b18b crank and put it into the b18c block ...and work from there...use the b18c tho
Old Jul 29, 2004 | 04:35 PM
NAredneck's Avatar
is this a street engine or a race engine????
i mean you could do with 11.5:1 or 13:1....but that should be your first big decision
Old Jul 30, 2004 | 02:11 PM
hondahb12's Avatar
Default Re: (NAredneck)
bout 13.1 cp i just wanna know which block would be better to sleeve,
Old Jul 30, 2004 | 04:04 PM
CompressionFed's Avatar
Default Re: (hondahb12)
I would stick with a GSR block.
Old Jul 30, 2004 | 04:32 PM
chad174's Avatar
Default Re: (CompressionFed)
GSR block. OEM girdle, oil squirters, various oiling enhancements, stronger all around than an ls block.
Old Jul 30, 2004 | 06:53 PM
NAredneck's Avatar
GSR block and LS crank
Old Jul 31, 2004 | 12:13 AM
H.A.R.T B18C1EG6's Avatar
Yeah GSR block
Old Jul 31, 2004 | 05:53 PM
hondahb12's Avatar
Default Re: (chad174)
can i still use my oil sq , with the bore of 85mm??? thanks
Old Jul 31, 2004 | 05:55 PM
hondahb12's Avatar
Default Re: (Manuel)
with da 87.2 gsr crank, would it still to be able to acheive 220 230,,
Old Aug 2, 2004 | 03:41 AM
93H22ACX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Manuel &raquo;</TD></TR><TR><TD CLASS="quote">A GSR block wit a 87.mm gsr crank works fine too </TD></TR></TABLE>
so are you saying a h22 crank can fit or a stroker crank?
Old Aug 2, 2004 | 04:44 AM
Tbone's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondahb12 &raquo;</TD></TR><TR><TD CLASS="quote">can i still use my oil sq , with the bore of 85mm??? thanks</TD></TR></TABLE>
I still do.
labatt50
Sep 24, 2006 12:28 PM
N20civicB18
Mar 26, 2006 03:08 PM
Corinthians
Oct 8, 2004 10:39 AM
street dreams
Jan 15, 2003 06:02 PM
