lower control arm
Old Jul 29, 2004 | 02:07 PM
AlekSir's Avatar
Default lower control arm
OK here's the deal
I lowered my car a couple days ago, and everything looked great.
Then, my friend told me, that I need to take my car up on a hoist and loosen the lower control arm bolts, apply some pressure on the car, and tighten them again.
He said to do this because my new springs are shorter than the original ones, the lower control arm will be acting like a spring becaus of some bushing in it bla bla bla. Anyway, he did that and he did it so that he did each wheel seperately since his hoist is not the one you can drive onto, but those arms that you extend to each of the 4 corners of the car.
So, now depending on what surface I park, I noticed the car sits lower on one side than the other, in both rear and front.....
Did anyone had anything similar?
it's lowered on TEIN S tech springs
Old Jul 29, 2004 | 04:43 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: lower control arm (AlekSir)
Your friend is an idiot. Loosen and tighten the control arms? WTF?
Anyway, you don't need to do that. The "spring" effect that the arms have are due to the sway bars that are on the car. Your car will sit differently on different surfaces because of the simple fact that your aftermarket springs are of a higher spring rate. Park on a slant, and you'll see the uneven-ness a lot more. It happens.
As long as you installed the springs correctly, that's all you need to do.
Old Jul 29, 2004 | 07:02 PM
AlekSir's Avatar
Default Re: lower control arm (shamoo)
do u think loosening and tightning these bolts may have caused this..guess not
hmm ok thanks for your info
i hope to get some more responses
Old Jul 29, 2004 | 09:55 PM
shamoo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AlekSir &raquo;</TD></TR><TR><TD CLASS="quote">do u think loosening and tightning these bolts may have caused this..guess not</TD></TR></TABLE>
I highly doubt it. The control arm movement is not restricted at all by how "tight" the bolts are holding it. There are bushings placed in certain locations that allow the control arm to move. No matter how tight/loose the bolts are, the arm will still move the same amount.
Be more specific when you say, "now depending on what surface I park, I noticed the car sits lower on one side than the other, in both rear and front....."
Old Jul 30, 2004 | 11:30 AM
AlekSir's Avatar
ya, i know there is a bushing inside. so they said this bushing if not loosened and tightened again will wear off afte time because of the spring effect, also the ride migh feel stiffer or something
well when I was parked in my driveway, rear right was lower than rear left, and the opposite was happening at the front...
then I drove m car into the garage, and I measured 60 cm in the front from floor to fender and 61 on rear right and 60 cm on rear left,, but I think it is this way because my rear left tire is almost worn off and rear right is like brand new
Old Jul 30, 2004 | 11:49 AM
dip-set's Avatar
drive it hard.let the springs settle..
Old Aug 1, 2004 | 04:43 PM
AlekSir's Avatar
Default Re: lower control arm (b18b-se)
anyone else
Old Aug 1, 2004 | 05:16 PM
spaceman's Avatar
did you install everything correctly?..if yes then your good to go..suspensions are not that complicated dood
decode33
Honda CR-V & Element
Oct 29, 2011 06:48 AM
thomst4R
Suspension & Brakes
Jul 17, 2005 06:20 PM
Lee_Delso
10
Dec 31, 2004 09:51 AM
skyliner186
11
Dec 29, 2003 08:39 PM
