Technical term for lower control arm
Trying to figure out with a rear lower control arm is called on car-parts.com, the options are:
-Trailing Arm
-Locating Arm
Which one is it? Here's a picture of the part...
-Trailing Arm
-Locating Arm
Re: Technical term for lower control arm (RedlinedVTEC)
I know what it's called but on car-part.com you have to choose and I don't want to make the wrong choice.
Re: Technical term for lower control arm (Lee_Delso)
it literally is called the Lower Control Arm or "LCA"
Edit: just re-read your post. my money would be with trailing arm.
Re: Technical term for lower control arm (SkoundrelUSA)
Okay if you go to car-part.com after you enter your info and click on control are-rear lower then it brings you to a another screen and gives you the option of trailing or locating. Hope this link works http://car-part.com/cgi-bin/search.cgi
Well link doesn't work but here's what it looks like:
Select your option
Locating Arm, forward
Locating Arm, rear, SI, w/o ABS Right
Locating Arm, rear, SI, w/o ABS Left
Locating Arm, rear, S Right
Locating Arm, rear, S Left
Locating Arm, rear, SI, w/ABS Right
Locating Arm, rear, SI, w/ABS Left
Locating Arm, rear, VTEC (DOHC) Right
Locating Arm, rear, VTEC (DOHC) Left
Trailing Arm, drum brakes Right
Trailing Arm, drum brakes Left
Trailing Arm, disc brakes, w/ABS Right
Trailing Arm, disc brakes, w/ABS Left
Trailing Arm, disc brakes, w/o ABS Right
Trailing Arm, disc brakes, w/o ABS Left
Select your option
Re: Technical term for lower control arm (Mr. Vapor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Vapor »</TD></TR><TR><TD CLASS="quote">
Edit: just re-read your post. my money would be with trailing arm.</TD></TR></TABLE>
I'll take your money then. Trailing arm is what the rear hub/brakes are on.
cute little bastard
i wouldnt pick a mysterious choice, but if anything go to ebay and look for one.
what car is it for by the way. ill try to find it for u
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA »</TD></TR><TR><TD CLASS="quote">i wouldnt pick a mysterious choice, but if anything go to ebay and look for one.
what car is it for by the way. ill try to find it for u</TD></TR></TABLE>
97 Del Sol SI, I have some SPC arms on now but they suck ***, want to go back to stock.
Cheeseng35
12-13-2017 04:04 PM
