Integra Rear disc conversion for '97 Civic
I swapped out those crappy drum thingies in the back and put Integra discs in the rear. The discs are from a '95 while my car is a '97. Come to find out, the passenger side trailing arm is bent. I got a camber kit to fix the camber, but adjusted the toe all the way in and the tire still points out a little. Can I use my stock rear trailing arm to replace the 'Teggie one? Thanks in advance!
And here is a thread I made a while ago on how to run your factory trailing arms with the rear discs with a list of tools https://honda-tech.com/zerothread?id=426445
boostitalready
Nov 25, 2012 04:36 PM
eghatchproject
Mar 16, 2004 07:05 AM
soundbomber
20
Jan 20, 2004 02:29 PM
91SIR
Apr 22, 2003 01:56 PM
