MSD 6plus Problems
Old Jul 29, 2004 | 12:51 PM
systemflits's Avatar
Default MSD 6plus Problems
I have a MSD Digital 6plus with a blaster2.
I believe that I connected everything oke, but when I start I get no spark and ECU error 15 Ignition Output Signal ~ missing or defective ignition output signal.
I have a Honda Crx DOHC "90 MK2 D16Z5
The white MSD wire is connected with the original coil with-blue
The red MSD wire is connected with the original coil black-yellow
I think that the problem is in de distributor-cab,
Its from a B16A1, could this be the problem?
Old Jul 29, 2004 | 03:22 PM
CHEETAH's Avatar
Default Re: MSD 6plus Problems (systemflits)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by systemflits &raquo;</TD></TR><TR><TD CLASS="quote">
original coil or distributor ? the red msd goes to ign power = blk/yellow thick wire on distrib plug and the white wire should NOT go tot he blue wire (whihc is tach signal) it should go to the igniter wire (on your distrib plug its the single wire that doens;t have a partner next to it int he plug).
this is from memory, but hope it helps.
greg
hondahatch91
Jan 5, 2010 09:10 PM
swapped95
12
Dec 29, 2006 12:38 PM
_Endless_
Nov 1, 2002 07:49 AM
uneekcrx
Apr 11, 2002 09:05 PM
JDM R98
Aug 8, 2001 07:47 AM
