MSD Help!!!
Old Aug 7, 2001 | 06:44 PM
JDM R98's Avatar
Default MSD Help!!!
can someone give me step by step info on how on to install a MSD 6AL in my R?thanks
Old Aug 7, 2001 | 07:07 PM
DB2-R81's Avatar
25 Year Member
Default Re: MSD Help!!! (JDM R98)
MSD Installation 6 series or SCI systems and stock coil.
If your using your stock coil the set-up is thin red wire coming from
the MSD connects to the black/yellow wire coming from the Ignition
Control Module. This is the only connection that you actually splice into, do not
disconnect the wire from the Ignition Control Module. But do
disconnect this black/yellow wire from the coil. You can make this
connection out side the distributor if you know which wire to connect
into. (Hint, the thin red wire coming from the MSD connects to the
black/yellow wire, which originally comes from the ignition switch. IF
you have a Helms manual see the Ignition System circuit diagram.)All
other wires are disconnected from their original connections and
butted to their new connections. The thin white wire coming from the
MSD connects to the white/blue wire coming from the Ignition Control
Module in the distributor. And the thin black wire coming from the
MSD connects to the coil - neg side and the thin orange wire coming
from the MSD connects to the coil + pos side in the distributor. The
coil may be marked. Connect the thick red from the MSD to the battery
and black wires from the MSD to a good ground and that should do it.
This again is for 6 series or SCI systems and external coil.
OK, first locate the stock coil in the distributor (should have a
blk/yel wire (+) and a blue wire (- trigger.) Disconnect both wires
from the stock coil completely. Connect the blk/yel wire to the thin
red wire on the MSD. Hook the blue wire to the thin white wire from
the MSD. Then, connect the orange wire from the MSD to the + terminal
on the MSD coil and hook up the thin black wire from the MSD to the -
terminal on the coil. Connect the thick red from the MSD to the
battery and black wires from the MSD to a good ground and that should
do it.
I mounted mine under the passenger seat and I am using the stock
coil. Soldier all your connections and use shrink-wrap to insulate and
protect your connections. I made the connections in such a way that
should the MSD ignition system fail, I just have to connect one
connector together and the system is back to working stock. I have
some pictures and if you need more help let me know.
Old Aug 7, 2001 | 07:37 PM
Vtec-R's Avatar
New User
Default Re: MSD Help!!! (DB1-R81)
Actually I'm thinking of upgrading my ignition system in the near future and I'm interested in seeing the pics.
Old Aug 7, 2001 | 09:08 PM
JDM R98's Avatar
Default Re: MSD Help!!! (Vtec-R)
yeah pix will help..
Old Aug 7, 2001 | 10:23 PM
JDM R98's Avatar
I dont believe the 6AL have a ground wire ..you just connect the thich black to the neg and red to postive
Old Aug 7, 2001 | 10:35 PM
B18C-EJ1
Guest
Posts: n/a
Big thick black to NEG is the ground.
Old Aug 7, 2001 | 10:37 PM
JDM R98's Avatar
Default Re: MSD Help!!! (B18C-EJ1)
okay..the thick black one goes to the ground..so nothing goes to the neg terminal of the battery?cause thats all the wire left.
Old Aug 7, 2001 | 10:39 PM
JDM R98's Avatar
because on the back of the 6AL box say the heavy black wire goes to the neg terminal of the battery..So you guys saying that heavy black wires goes to a ground?
Old Aug 8, 2001 | 03:05 AM
C-speed's Avatar
Check here - pics and instructions:
http://www.c-speedracing.com/howto/msdbtm/msd.html
HTH
Old Aug 8, 2001 | 07:47 AM
JDM R98's Avatar
Default Re: MSD Help!!! (G3-TEG)
thanks for helping out you guys..I am goin to start on it tommorow morning first thing , and also work on putting in the energy suspension motor mounts inserts..thanks
swapped95
12
Dec 29, 2006 12:38 PM
connvict
Jul 29, 2004 08:54 PM
systemflits
Jul 29, 2004 03:22 PM
darklude111
Mar 3, 2002 06:53 PM
