scraping noise from drivers side
Old Jul 29, 2004 | 12:26 PM
lswift's Avatar
Default scraping noise from drivers side
watup ive been getting a slow scraping noise from my drivers side hub, its not that loud ive got to turn off my cd deck for me to hear it but when im slowin down i can hear it griding. i did my pads and had the rotors resurfaced about 2-3 months ago. is the rotor fucked? i had some 17" racing harts on there that i sold now im on oem honda rims for the DX. help.!!
Old Jul 29, 2004 | 12:54 PM
SOHC50shot's Avatar
Default Re: scraping noise from drivers side (lswift)
are your lower at all?
Old Jul 29, 2004 | 01:19 PM
Frozen E's Avatar
H-T White Ops
Is it kind of a wobbling scraping sound? If so does the speed of the wobble change with vehicle speed? If yes, you have a wheel bearing going out on you.
Old Jul 29, 2004 | 01:46 PM
lswift's Avatar
Default Re: (IslandSi)
i hear it mainly when im slowing down to a full stop for like a light or a stop sign (i stop for em sometimes...) so it does change as the speed decreases, i cant tell if its doin it as im accelerating.. cuz well im accelerating andi can hear the engine (hole in exhaust manifold thats gettin replaced with a header soon...)
Old Jul 29, 2004 | 02:51 PM
lswift's Avatar
Default Re: (lswift)
anyone?
Old Jul 29, 2004 | 03:13 PM
3.3.3's Avatar
i would say the pads were worn out, but you just recently replaced. check the metal piece that is behind the rotor to make sure it didnt bend up against the roto. i had the same sounds (metalic scraping sound) and i jsut bent it back, and voila! gone!
are the tires rubbing at all? are they tucked under the fender?
Old Jul 29, 2004 | 03:23 PM
hondainspired's Avatar
yes... def check the sheild plate thingy behind the rotor.. first take a look at it then next just pry it back... i've had two cars now that did the same thing...
angrysmileyface
Jun 22, 2019 06:14 PM
syknxv3
Sep 21, 2008 09:00 PM
crxsleeper210
11
Jul 21, 2008 07:41 PM
p nut
Apr 17, 2003 08:48 AM
Pele
Mar 3, 2003 07:23 PM
