300 mile plug check....how do they look?
Old Jul 29, 2004 | 10:53 AM
Nihilation's Avatar
Default 300 mile plug check....how do they look?
Running 6psi on a GSR.
Plugs are NGK-R's...BKR7E's I think. Heat range of 7 for sure.
Labeled the way they were removed...from right(1) to left(4).
Old Jul 29, 2004 | 11:06 AM
DigitalFusion's Avatar
they look pretty good to me, but what is that gap set at? I dunno, looks smaller than .030
Old Jul 29, 2004 | 11:07 AM
rudebwoy's Avatar
they looked a little lean
Old Jul 29, 2004 | 11:08 AM
its only been 300 miles tho
m R g S r's Avatar
Default Re: (rudebwoy)
I think they look fine. What managment are you using? The gap doesn't look too small, but what is it anyway?
Old Jul 29, 2004 | 11:43 AM
Nihilation's Avatar
Gap is between .028 & .032
Engine management is Hondata S100B w/440cc's and Walbro 255 pump.
Old Jul 29, 2004 | 12:03 PM
ATS*Mark's Avatar
OG triple OG
Default Re: (Nihilation)
i wouldnt gap them bigger than .030..... .028 seems to be the sweet spot.
but your plugs look pretty good to me , have you been boosting on it ?
Old Jul 29, 2004 | 01:29 PM
Charlie Moua's Avatar
Default Re: 300 mile plug check....how do they look? (Nihilation)
OT:what kind of power are you making on 6psi?
for 300miles that is about right.
if they look like that after 3,000 miles your definaly getting lean too offten.
Old Jul 29, 2004 | 02:39 PM
Nihilation's Avatar
Hella_JDM- The car made ~18 dyno pulls during tuning this past Monday. Since then I've probably done about a dozen WOT pulls on the street.
Charlie Moua- At 6psi it made 212whp with a leaking wastegate which was causing extremely late spool up. It made 232whp on 8psi as shown here- http://jtaylor.u24.hosting.thr...0.jpg
Notice the late powerband. Heh...
Old Jul 29, 2004 | 03:17 PM
pollito's Avatar
Plugs look great.
MotorSpecies ver1.6
Mar 1, 2008 02:34 PM
B18C1CYA
May 29, 2006 07:19 PM
Honduh Chicken
Aug 10, 2005 07:28 AM
handa
21
Apr 2, 2005 11:43 PM
Floyd
Jun 18, 2002 01:35 AM
